Question about GE Refrigerators
My ge side by side fridge is not working properly please help me. the freezer side does not freeze anymore it's about as cold as the fridge side what can i do and what is wrong
  • 612 Answers
Check the inside back lower wall inside the freezer. If it has ice built up on it, you will most likely have a defrost problem. This will most likely be a bad heater. You can remove the panel and use a hair dryer to melt ice. The heater is wrapped around the coil inside.
Posted on Nov 17, 2009
Veg and fruits freeze up.. Why? and what should temps be for frig and freezer?
We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: http://fixitnow.com/wp/2007/12/06/ge-side-by-side-refrigerator-freezing-the-beer/. You also might need to enter a diagnostic code when you replace it. Check this out also:
http://fixitnow.com/wp/2009/10/02/activating-self-diagnostic-mode-in-a-ge-arctica-refrigerator/. Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
Jun 14, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Jun 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Refrigerator Not Cooling (TFX27ZPBGWW)
The unit isnt defrosting hence the ice on the back panel. Either your bimetal thermostat is open or the heating element is shot. Most GEs they come together so happy hunting. Those parts are behind the frosting panel
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Do I need a compressor on side by side fridge
u might have a dfrost problem ge well known for that try unplugging for 4 or 5 hrs leave doors open plug back in if works fine its the defrost then u will nered defrost heater tstat and main board vey expensive cheaper to get new
Mar 18, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
