Question about Cell Phones
IM TRYING TO PUT MY BOOSTMOBILE SIM ON MY AT&T LG GR500 PHONE BUT I NEED TO UNLOOCK IT CAN ANY 1 HELP ME OUT WITH THAT CAN YA GIVE ME THE CODE
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Aug 03, 2011 | LG Xenon GR500 Cell Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
I need the unlock code for an Lg gr 500 xenon.IMEI # is 012011005719292. I'm trying to unlock the phone to put my sim card in it and use it. It was a gift from my brothers ghirlfriend so I'd really...
First, you must asking to your brother girlfriend what is the LG Xenon GR500 original sim card network , then you can decide to use LG Xenon GR500 unlock code in apropriate network. You can get lg unlock code by calling the original network phone provider, but the only person that can do that things is your girlfriend brother. Another solution you can buy lg unlock code from third party sites with lower cost and fast delivery rather than original network provider.
Apr 28, 2011 | LG Xenon GR500 Cell Phone
Lg xenon sim card locked, need a PUK code
You need to contact your cell phone service provider. They can give you the PUK code once you give them your account details and they can verify your details.
Nov 03, 2010 | LG Xenon GR500 Cell Phone
My husband is out of the country for 6 months and put a passcode on our phones and i am not on the account and i need my puk code.
you may just call customer care and ask for puk code and just need to give details about sim card owner tell them you his wife and need this code if don't give then ask any male to call and tell his details so they will definitely give you if have any problem can contact on aniruddh11@gmaill.com regards aniruddh
May 26, 2010 | LG Xenon GR500 Cell Phone
I purchased an lg gr500 second hand, i put my sim card in there and now its asking for security code, please help...
Absolutly you got locked phone and you need to unlock that phone before you can use your sim card on that phone. To unlock lg gr500, you will need lg unlock code for your network carrier. This unlock code can be purchased at third party sites on internet.
Jan 07, 2010 | LG Xenon GR500 Cell Phone
Whats a puk blocked
just contact the service provider for the puk code . its a sort of protection given to the service when any one miss use it by the service provider.
Nov 14, 2009 | LG Xenon GR500 Cell Phone
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
