Question about Sony KP-51WS500 51" Rear Projection Television
Our tv is blury, double vision with whites going
Our tv is blury, double vision with white lines going through it and not centered. The middle green bulb flickers at first then it will go out completely. iIf you turn the tv off and on again, it will light back up but soon after go out again
    Scholar:
  • 60 Answers
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Nov 28, 2009
    Genius:
  • 1,112 Answers
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Posted on Nov 19, 2009
Somebody cut the wires to my qocdc camera and i dont want to buy a new one how do hook it up?
Hi Jonathan,
Normally,
Double wire is power wire.+line has special mark like white line or red.
Screen wire is video line the middle one of it is signal and screen is ground.
regards,
nuwan
Jan 27, 2014 | Digital Peripheral Solutions Q-see...
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
My tv is green and red and shows everything in double vision it a samsung sp42w5hfx
thank you for visiting fixya. i would first try to go to my television menu with the remote and try to solve my problem. it seems to have convergence problems. if you would go to the part of your menu that says convergence then you would see some crosshatch patterns. try to get these patterns to become one if they are off centered. they should turn white when you have centered them up. this should solve your problem. if it does not then write back and we will go to the next step. this should save you some money and time. please rate my solution
Nov 16, 2009 | Samsung Televison & Video
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
240 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
