Question about Dell Dimension 8300 PC Desktop
UNPLUGED Someone unpluged all the ribbions inside my DELL DIMENSION 8300 and I don't know what plugs go to what hardware - can you help me ?
  • 59 Answers
You may check the Manual for Dimension 8300 at the following link it may help...
http://support.dell.com/support/edocs/systems/dim8300/en/index.htm
Posted on Nov 17, 2009
  • 64 Answers
Ribbons you should have 2 one for the cd rom drives and one for the harddrives, Look closley on the borad and it will say next to the connector which is which, the ata one will go to the harddrive and the ide one will go to the cd rom drive the end that only has one connector goes into the borad, the one with 2 connectors kinda close goes into the compoents, DO you have more than one hd if so you may need to find out which one is the master and which is the slave!
I'm trying to find out if the whole front panel power switch on the dell dimension 8300 can be replaced with a generic brand . I have changed the motherboard, replacing it with a SIS 648FX Foxconn board....
The problem you're running into is that Dell uses proprietary parts,like quite a few manufacturers still do.The board you bought should have come with a manual on a CD or DVD.You can look through the manual and see what the connections are,they're even printed,usually,on the board beside each set of pins.It's very small print.
What you have going for you is that the Dell multi-plug is also labeled as to what wires are for each application.You'll have to cut the plug off and put individual connectors on each wire,then connect them to the corresponding pins.You can get the parts at an electronic supply store,even Radio Shack.
Just be careful,and make sure that if your hands are inside the case,the cord is unplugged.
Bob
Sep 01, 2010 | Dell Dimension 8300 PC Desktop
I cant find sound driver
Suggest you download, and install the Audio driver, for the Dell Dimension 8300.
This is Dell Support and Downloads, for the Dell Dimension 8300 Desktop PC,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Sep 04, 2009 | Dell Dimension 8300 PC Desktop
How do I open a Dell Dimension 8300. I lost my manual
There are two release buttons, one is on the bottom of the case and one on the top. Lay the case on its side and depress these two buttons and the case opens like a **** shell. There are slide hinges attached to allow it tp open wide without disturbing the wiring looms inside.
Aug 31, 2009 | Dell Dimension 8300 PC Desktop
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
I BOUGHT CHEAP RAM, EBAY, DELL DIMENSION 8300 HUMMING
This system supports ECC and non-ECC Rambus modules. ECC and non-ECC modules can be mixed but ECC feature will be disabled. Modules must be installed in pairs. multiple modules - PC800 the max is 2 GBs
systems tool...run disc clean up...put a check mark in every box, you don' need anything there as it is all copies you have elsewhere...
then defraggment also in system tools.
If you really feel like making that ole girl hum, do a complete reinstall using the latest drivers from the dell site. If you use your service tag number it will select the better drivers for your application.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8100&os=WW1&osl=en&catid=&impid=
go to this page for drivers (above) select your operating system (2000-ME-XP-Vista).
hope this helps you. Please leave rating
May 06, 2009 | Dell Dimension 8300 PC Desktop
Speakers work but crackle when in use with my dell 8300
Most likely this is because of a loose socket. Check to see if there's any dust or debris inside the audio socket(s). If cleaning it/them out doesn't work, then the socket is loose and the only way to fix the problem would be to get the sound-card repaired or buy a new sound-card.
It's my opinion that buying a new sound-card would be cheaper. You can find a good amount of them at this website. Simply navigate to Computer Hardware>Input Devices. Now on the left click, "Sound Cards." Watch out, though. There's a link labeled, "Sound Card Accessories." However, it doesn't lead you to the same page.
Let me know if I can assist you further or if I need to explain anything mentioned above in more detail.
Mar 23, 2009 | Dell Dimension 8300 PC Desktop
Can't get on the internet after installing memory--Did I uplug?
- I would think so that the network cable is unplugged to your computer. Just like a telephone cord,
Mar 09, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
Alun Cox
