Question about Lofra MBX76MFI Dual Fuel (Electric and Gas) Kitchen Range
I am looking for replacement globes for the range hood of our lofra oven. They look like usual down lights, 230V40W, screw in but have a white collar approx 2 cm long between globe and screw part... any help please??? not sure of model number of stove..
  • 1 more comment
  • julzs Nov 18, 2009
    similar, but different. Mine has three ventilation panels at the front, buttons to the right of the unit and two globes at the back, behind the ventilation grills. You have to remove the grills to access the globes.. does this help?
  • julzs Nov 19, 2009
    Thank you so much! Not quite what I was looking for, but the website provided the answer. FYI the bulb is a PAR 16 Hi-Spot 50 mains halogen 40W 25° flood SES and I have found someone in Victoria who sells them. They list it as a Duralamp Halogen JDR. Thank you again!
  • javasquealer May 11, 2010
    http://www.lofra.it/catalogo.php?where=o...http://www.lofra.it/catalogo.php?where=o...http://www.lofra.it/catalogo.php?where=o... These are the products that lofra have at the moment in cooker hoods, does yours look like one of these?
  • 4 Answers
Ok, the bulbs that you describe are fairly standard energy efficient ones I think, have a look at the link and see if it looks right, the only complication is the size of the screw fitting, it will be either an E14 or E27 the E14 is the smaller.
http://www.lightbulbs-direct.com/bulbfinder/?w=6-11&v=220-250&c=Screw&f=Any&cat=25
I hope this helps, and good luck!
Posted on Nov 19, 2009
Testimonial: "Thank you so much. Finally, after weeks of frustrating searching! It was a PAR 16 Hi-Spot 50 mains halogen 40W 25° flood SES found on the website"
Lofra oven doesent stay alight
I had the same problem with my Lofra, I removed the cover on the bottom of the inside of the oven and then unscrewed the metal bit under that. Then I tested it again so I could see why it wasn't lighting up. Turns out the heat sensor was in between two flames and wasn't detecting that the gas was on. I wiggled things around a bit until it stared working, then put the cover back on. Now it works wonderfully. Now I just have to fix the timer.. It doesn't ring when it reaches the end. Hope this solution works for you guys.
Dec 18, 2012 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Nothing on my lofra oven works small oven fine top fine oven died no lights or fan
Hi You need to check out the fuses and the power supply. Dont forget to check the power point as well.There seems to be no power supply to the unit.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
If my front pasenger is burned out is it just the
This vehicle is new enough it is just the Bulb for the head light. Open the hood and look in the area just behind the head light and you will see the wires leading to it. You should also see a collar looking connection you can unscrew to remove the bulb assembly. Remove this and unplug the bulb and insert the replacement and re-insert the assembly screwing the collar down. Make sure you get the collar screwed back down completely, this is what makes the Headlight assembly water tight.
Jun 25, 2010 | 2005 Lexus RX330
Broken oven element
All sorted now. Found a company in Liverpool, very helpful. Posted replacement today.
Feb 01, 2010 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Door seal small oven needs replaceing
many thanks, sorted. ordered at local supplier. regrards tb.
Dec 08, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi, We have a Lofra oven. The door no longer
Sorry,
you are screwed I am in the same position. Tonight I am going to the store where I bought it with a baseball bat and intend to smash the owners legs.
Oct 13, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Can't find parts for Lofra range cooker
do you have a clue where i can grip some knobs for lofra gas cooker.
MXUD66GGI. i have tried every where can you help me.thanxs.
Jul 15, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
LOFRA oven won't ignite/what are these symbols?
Figured out the triangles mean fan. I blows the hot air down. Still no clue about the other one. Found the sparky thing and scrubbed it with a wire brush (making sure the gas was off). After many more attenpts I turned on the top burner and tried again and it lit finnnnnaly.
May 28, 2009 | Lofra PXUD66GGI/C Gas Kitchen Range
Kitchen Ranges Logo
296 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
ray gallant
David Ellis Rhea
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
