Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error code 5110 on canon mp830 copy and alarm flashing
    President:
  • 787 Answers
5110 is Carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 17, 2009
2 Suggested Answers
  • 123 Answers
SOURCE: Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Posted on Jul 21, 2010
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Have a Canon MP830. in the middle of printing, it came up with error code 6A00, and now all it does is flash the alarm light and copy light. how to fix?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#BrochuresAndManuals
I would download the manual for windows 7 and see if the 'alarm and copy light flash' error is listed. I could not find it referred to in the support area of the canonusa.com website. Also, you could call 1-800-OK CANON and talk to a rep. about this problem.
Good luck on this repair.
Feb 06, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I received a used Canon MP830 (without a manual). The error code comes on the screen 5110. What does that mean? Can a I download the manual for free?
You can download the manual from the manufacturer's web site at
Jan 11, 2011 | Canon PIXMA MP830 All-In-One InkJet...
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
What is error code 5110 mean?
According to the manual, error 5110 means "Carriage lift mechanism error".
It's usually related to cartridges, particularly if they not inserted correctly, but can also be caused by other mechanical failures.
Apr 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My MP830 has an error code of 6A00. The assembly
6A00 means the purge assembly is jammed or worn out. Part number QM2-3032-000 around
$30.00. It's the cleaning assembly on the right where the printhead parks when shut down.
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
998 people viewed this question
old marine
old marine
