Question about Whirlpool Washing Machines
The agitator spins automatically(not the drum)when the power is switched on and stops only when power off in the top loading fully automatic whirlpool washing machine
  • 612 Answers
If you saying that the machine agitates when ever it's plugged in. You will most likely have a bad timer. You will find that the points are welded together inside the timer
Posted on Nov 17, 2009
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
When spin cycle stops the agitator stops but the tub spins and makes a loud banging sound
it sounds as if one of your springs has broken or become detatched from the outside of the drum. open the top cover and have a look. ensure the power is switched off.
thanks iain
Apr 28, 2011 | Kenmore Washing Machines
Drum fills with water but won't agitate. spins and rinses fine.
Hi.
If it does not agitate check the variable speed motor, the control unit and the transmission.
Check also the lid switch. A defective lid switch may open the circuit and stop the cycle before agitating.
Nov 13, 2009 | Maytag PAV2300 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Kenmore elite top loadwasher spins and pumps but will not agitate
Hello, your problem is not the motor, it is the drum shaft collar or what the tub rests on. It is on the top of the shaft. You need to remove the shell, the plastic collar that rests on top of the drum, the agitator, then the nut that holds the drum down, and then pull the drum out, and then you will see the collar. I know it is hard to get to so I would call a pro for this job unless you think you can do it. The part is cheep it is the labor that will cost you. Thank you
Dec 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
to answer your first problem,
if it wont stop filling, then the pressure switch is either defective,
or the hose that is attached to the drum to the pressure switch was either pulled out or had an opening either it breaks or it cracks.
that would not transfer the filling mode to agitate mode.
the second problem that it wont drain and spin now is another issue but might be resolve if you solve the first problem.
tnx 4 using fixya,
drcool
Aug 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
