Question about Car Audio & Video
LOOKING FOR COLOR OF WIRE TAKING POWER IN TO THE RADIO.IT IS A KENWOOD KRC-X858
  • 145 Answers
Red is the 12 volt power line. yellow is the memory line(constant 12 volts) . small red wire is the switchable 12 volt line that only has 12 volts when keys in ignition
Posted on Nov 17, 2009
Im tring to match up this radio wireing to a chrysler lhs i need to know what colors go to what the kenwood krc 235 wire to the chrylser car wireing (red to pink blue to orange like that)
I recommend you purchase a wiring harness specific for that vehicle instead of trying to hardwire it. You run the risk of frying your entire electrical system if you do. Wiring harnesses are about $7-$20. Plus, it takes the guesswork out of wiring. Visit www.crutchfield.com if you are looking for one.
Aug 14, 2011 | Car Audio & Video
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Wiring diagram for Kenwood KRC-2007?
red wire is key source black wire is ground yellow wire is menory 12 v source is that is on all time rest are speaker wires make sure u put the full color wires as ur pos side then the wires with a blk line thur is neg side
May 15, 2010 | Kenwood KRC-2007 Cassette Player
The motorized face plate only sits at the half-way
the flexible cable that goes from the face to the main motherboard is probably bad and needs to be replaced
Dec 10, 2009 | Kenwood KRC-X858 Cassette Player
Kenwood KRC-x858 stuck halfway between closed and open
have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable2_bing.gif is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Jul 23, 2009 | Kenwood KRC-X858 Cassette Player
Faceplate stays half opened, half closed will on not turn
I have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Nov 21, 2008 | Kenwood KRC-X858 Cassette Player
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
