Dont know what the part is called but it is the little round knob on the right handside of the radio when you are looking at the radio the little piece that the knob goes into is broke it square on one side an round on the other side
  • 566 Answers
If i understand you well, that part is called potentiometer or variable resistor or just plain volume control
Posted on Nov 17, 2009
Wiring diagram for off and on volume nob ?dont know where color wiers connect
before you replace it and remove the old knob , look at how the wires are connected and snip the so you have a little color showing. Now , with the new knob you just attach the wires back to the location they were in on the old knob.
Aug 13, 2015 | Radio Communications
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds http://www.chryslercommercialvehicles.com/jeep/download/pdf/manuals/2014-Patriot-OM-1st.pdf page 240
Mar 12, 2015 | 2014 Jeep Patriot
Why don't I have sound on uniden pc78ltw?
the knob that turns the radio on and off is the volume potentiaometer.turn it 1/2 wayopen.the next knob is the squelch maqke sure it is all the to the left.the next knob is the mic gain and the RF gain.Set the mic gain at 1/2 and the RF gain all the to the right.the next knob is the delta tune,set it 1/2 way the next knob is the calibration knob leave it alone.Now above those knobs are little switches .the third switch from the left is for CB/PA make sure its on CB. check the WX switch and make sure it not on a weather station. and finally the last switch to the right is called a dynamic squelch switch.Make sure it is down. with all said your radio should be on and you should be able to hear sound. If not ,take an external speaker and hook it to the external speaker plug in the back of the radio.If you hear something then you internal speaker is junk.replace it .
Sep 04, 2014 | Radio Communications
Need a manual for an old sanyo tv,model number ctp 3104 .Do not know how to tune it in .thanks sue.
The silver around the knob on the right handside is for tuning and the knob in the middle is for fine tuning the signal in,
Hope this helps :-)
Aug 10, 2011 | Televison & Video
Furnace pilot ***,furnace will not ignite,has
Look around the burners. Look for a little round cylinder with some wires attached and a small knob that you push in to reset. There will be more than 1 of these. You should also try to figure out why it is tripping.
May 30, 2010 | Coleman Heating & Cooling
Need to change a tail light bulb left sideon a 2000 vw bettle
Unscrew the knob behined the light in the Boot / Trunk and the use a small screwdriver on the OUTSIDE of the light on the right handside as you look at the light in the middle on the outside. You will feel a little spring clip and as you push gently the light will pullout forward.
http://laudeman.com/volkswagen/
Go to the above link and you will get picture wise explanation for the same tail light bulb replacement. It has step by step picture explanation.
Oct 05, 2009 | 2000 Volkswagen Beetle
I dont know were the adjustment nobs should be i just got this radio and dont know that much about the galaxy 959
There are little red dots on the edge of each knob. As a starting point, try these knob positions (starting from the knob on the left)..
Adjust volume as desired.
Adjust squelch all the way counterclockwise (no squelch).
Adjust mic gain so the red dot is at the 12 o'clock position.
Adjust light dimmer as desired.
Adjust RF Power with the red dot at the 12 o'clock position.
Ignore talkback and clarifier for now.
Now for the 5 little slide switches...
Set all of them to the middle position.
Now you should be able to operate transmit and receive.
This is a very good radio, but there are so many adjustment knobs that you can reduce its performance if you just blindly turn knobs.
After you learn how the radio sounds and works with these average settings, play with each knob, adjusting a little and see what it does for your particular antenna setup. Do some "radio checks" with other CBers and find out what your best settings are. Also read the owners manual for guidance on what each knob does...especially mic gain (too low and you won't be heard, too high and you'll be garbled) and RF Power (to little and you won't reach out very far, too much and you'll overload local listeners). This is definitely not a beginners radio. But it is a lot of fun and will enable you to learn a lot.
Jul 10, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Clock settings
Phaedrus De Wolf--
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
Nov 26, 2007 | Pioneer DEH-P2900MP CD Receiver...
Loud speaker during call
When the call will be in progress u have to see on the right handside corner of the screen of ur handset, option of "loudspeaker" will be there OR u go to "options" on the left handside of corner of screen.Press it and loudspeaker will get activated.
Oct 20, 2007 | LG KG800 Cellular Phone
No Sound
well, if it powers up, youve still have hope// check and see if you can see a fuse holder at back of stereo... or go to a radio shack or electronis place and get whats called 'contact cleaner' ( may go by a different name, make SURE you know that the salesperson knows what your talking about..PS.you dont have to buy the pricey stuff, but dont get the cheapest either.) then UNPLUG stereo, make sure its not hot ( dont have it on for a long time before working on it) then pull out the knobs on the front ( the volume,left/right,etc) spray a LITTLE bit into the stereo where the plugs go.dont drench it, a little goes a long way) after spreying it in, turn the knob back and forth so it gets to all the points.... make SURE its dry before plugging it back in, you can tell if you see any moisture where you sprayed.( another reason, not to spray much) i usually let my stereo and tvs dry over night before trying them.while your waiting, may as well take a cloth and clean the face, get any cruddies off... good luck
Mar 12, 2007 | Kenwood VR-405 Receiver
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
