Question about Sony KP-51WS500 51" Rear Projection Television
THE PICTURE IS BLURY, DOUBLE VISION, LINES THROUGH THE WHOLE PICTURE, NOT CENTERED AND THE BULBS COME ON BUT THE GREEN BULB IN THE MIDDLE KEEPS FLICKERING ON AND OFF, IT NOW HAS GONE OUT COMPLETELY BUT WHEN YOU TURN IT OFF AND BACK ON AGAIN,IT LIGHTS BACK UP BUT GOES BACK OUT AGAIN
  • 460 Answers
Your sony proj. tv needs a new convergence module. that is why it had the separated red green and blue lines. it finally shorted out all the way.. if the set means a lot to you then by all means call a sony qualified service technician and have it repaired..
Posted on Nov 17, 2009
  • john regrut Mar 08, 2010
    there is a broken solder connection for the filiment on the green crt board. there is access from the front of your set. if you know anything about soldering you can take care of this yourself. if not call a repairman.
  • 145 Answers
Try unplugging and pligging it backin 2 minutes later. this resets the microprocerssor
We had a power surge now our picture is blury like double vision
There is a bad capacitor on the power board of the television that is why you are having the blurry double vision on the television. Have the power board checked for bad capacitors that need to be replaced.
Hope this helped. All the best Elect_Comp
Oct 09, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Our tv is blury, double vision with whites going
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Nov 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a blury picture and lost the color green.
sounds like a blowen bulb
doctor i think it's time to open her up and look inside from the back
open rear cover and turn it on look to see if all the bulbs are working
if a bulb is dead then you figured it out and with a little work can save some cash on a repair guy
Aug 03, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Picture is in showing in double vision with colors serperated
bulb is going out. go back to where you bought it to see if warranty will cover it. if not, buy another bulb. ours was like, 40 bucks.
Apr 26, 2009 | Televison & Video
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Jvc
I have the same problem on my tv - the colors are seperated - the picture is blury and in converge mode the colors will not line up.
Need to know if I need to go and buy a new flat screen tv.
Any advise is appreciated. Thanks
May 25, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
195 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
