Question about Panasonic CT-32HX41 32" TV
TV keeps powering off
So I'm sitting down watching TV a couple of weeks ago and my TV turned off. Looked around to see if the kids were playing with the remote. Nope, nobody hit any buttons. I tried powering the unit back on with the remote and nothing. I tried powering on at the power button on the front, nothing. I unplugged the Tv and plugged into a different outlet and turned it on. Surprise it works. An hour later it did it again. I unplugged an plugged back in the same outlet that it started doing this with. I t worked again for a while and eventually got worse over the last 2 weeks. Now I can only get it to work for about five mins at a time. Any ideas???
  • spsutka Feb 15, 2009
    I have the exact same thing happening. We switched from Bell ExpressVu to Star Choice today and the tv was on for about an hour or so and then shut itself off. We also plugged it in after it would not turn on from pushing the front button or the remote and it worked for about maybe 20 seconds and again shut itself off. I am soo ticked! I don't know what the heck is wrong with it.
    Top Expert:
  • Panasonic Master
  • 75,767 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 05, 2017
bluenadas
  • 203 Answers
SOURCE: Turns off after a few seconds
The unit is going in to shutdown. There is a short in the unit. My guess would be the HOT and or Flyback are bad.
Posted on Jun 08, 2007
SOURCE: Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
Posted on Jun 12, 2007
SOURCE: Need Help big screen turns on thens goes off
The blinking light tells you what is wrong with the circuit. If it blinks 3 times it is the convergence amplifiler. I had this problem and tried to fix it myself and I don't think that I have it connected good enough. I know this is the problem with mine. I will let you know if this fixes that. Let me see what 5 blinking lites mean. I will tell you what each blink means from the repair manual, 1 blink is +140 circuit, 2 blinks is Low DC, 3 blinks is convergence, 4 blinks is HHS, 5 blinks is IC4011, 6 blinks is IC4018. I hope this helps. You can get a repair manual at servicemanuals.com it really helped me. I will let you know how my repair goes. I hope this helps. Rick
Posted on Dec 12, 2007
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
SOURCE: panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Posted on Nov 25, 2008
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
2010 Mazda 6, room fuse. A few weeks ago, my radio, interior dome lights and power locks all stopped working at the same time. Come to find out the fuse labeled "room" was blown. Replaced it and didn't...
I just had the same trouble in a 02 mazda millennia. found the SHORT.it was in the wiring of the drivers sun visor lights. no kidding, too simple. I hope yours is as easy to fix,,
Aug 22, 2013 | Mazda Cars & Trucks
Poulan Leaf Blower red hot muffler
you need to turn the Hi screw on the carb in 1/4 of a turn.
Jul 22, 2013 | Poulan Garden
TV does not seem to get power, wont turn on
It may be just the co-incident that the TV decided to stop working, right now the 5vdc standby (you said you can see red light inside) is working but not the rest, the power cord is not the cause of the problem.
You will have to open it up start checking inside or have it repair.
Try leaving it unplugged again for about an hour just to see if it will reset itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 24, 2010 | Vizio L32 32 in. LCD HDTV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Memorex 32'' LCD TV/DVD combo, DVD will not play
funny how **** happens....mine turns on and says memorex then stays on with no picture or sound.
Aug 10, 2008 | Televison & Video
I JUST BOUGHT this TV from my mother two weeks ago.
First of all, if the set is only 3 months old or so, there should still be a warranty on it. The store where it was purchased should have a record of it and should be able to provide you with a copy of the receipt which you will need to get warranty service. Try going back to the original store with the TV in the box. There should be price tags or some other indication of the store on it. Request an exchange by speaking to a manager. Thay may exchange it for you.
It sounds like there is a problem with the power supply section of the set. This could be a defective part ot two that is a manufacturing problem. Try the exchange and keep us posted.
Dan
Jun 03, 2008 | Sanyo HT32744 32" TV
Random ARC Picture Size Change
What Brand TV do you have? What cable box are you using?
Dec 07, 2007 | Televison & Video
Panasonic CT-32HX41 32" TV Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
