Tv is not recieving power ?blown fuse, how do i check and replace?
  • 66 Answers
Call for a technician to repair your tv power supply and cable
Posted on Nov 17, 2009
BNO POWER TV FUSE ALWAYS BLOWN..
There is a short somewhere on the board causing the overload. You will have to get the power supply checked.
Jan 20, 2013 | LG Televison & Video
I try to turn the tv on but there is no power.
check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Sep 21, 2011 | Sanyo Televison & Video
Recieving no power even though plugged into good outlet. is there a fuse?
Hello
Ofcourse there is a fuse in the AC track of every TV. But if fuse must blow, there must be some reson for that. Fuse is included in the path of AC as a protecion to the circuit for over voltage of over current. Just look inside, and confirm the fuse is blown or not. If blown, find out the reason for that and tectify it before placing an other fuse in place. Otherwise, the fuse you replaces will also blow out. OK.
Feb 17, 2011 | Hitachi 57F500 57" Rear Projection...
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Jul 12, 2009 | Pioneer VSX-454 Receiver
RCA TV blown fuse
Hi
you have bad Rectifier Diode or Ic regulator.. check first the unregulated power supply before you go to regulated power section! then check,.
Thanks!
Likha
Oct 23, 2008 | RCA F27242GY 27" TV
Reciever wont go on
Your are running out of power !!
Feb 02, 2008 | Onkyo TX-SV444 Receiver
No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Dec 22, 2007 | Panasonic SC-HT730 System
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Power
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Dec 27, 2005 | RCA RT2380 Home Theater System System
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
