Question about Extron Electronics Switching and Transmission System (tps150-1)
The car starts good but when you shift to reverse or drive the engine just die
  • 67 Answers
Diagnostic scanner first, converter clutch stuck on
Posted on Nov 23, 2009
After ideling a while i try to shift into reverse or to drive and it always dies .......any tips or ideas?
engine dies when shifting into reverse or drive - Third Generation ...
www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Feb 11, 2006 - engine dies when shifting into reverse or drive ... After it dies it starts right up and idles fine in park or neutral. ... these ignition items because you weretrying to cure the stalling, or, did the stalling occur after you replaced these items? ...The only thing that kept the car running was adjusting the Idle screw up.
Engine Dies When Placed In Gear***Split from Spittybug...EFI ...
dmctalk.org > ... > MAIN FORUMS > Custom DeLoreans/Mods > EFI
Jul 5, 2012 - 18 posts - ‎4 authors
Just to give an update on my car - I've been having an issue with the car stalling when moving from Park into Reverse or Drive (I have automatic). ... I have been playing with the idle advance trying to get more ... I put in the remainder of the AT fluid I had on hand and the car never died on shifting after that.
starts but dies when shifted into drive or reverse - Suzuki Forum
Jan 26, 2016 | Cars & Trucks
Car dies when shift into drive
I have seen this problem in a lot of cars in the transmission world. If you can feel any kind of a bind before the engine dies there's a chance you might have a lockup problem with your torque converter. This is just an idea for somewhere to start.
May 11, 2014 | 1994 Dodge Intrepid
Car dies when put into reverse
Is it possible the engine block is shifting in reverse and something in the wiring harness or a vac hose is being affected ?
Jun 13, 2013 | 1996 Buick Century
1995 Ford Bronco engine dies when shifted into drive but runs in reverse or 1st gear
Could be fuel filter,air filter,tune up,wires,coils.low idle too low.
Jun 13, 2013 | 1995 Ford Bronco
1997 Carolla- engine dies when shift to reverse or drive, starts again when put in park. Is this a transmission problem or starter/ignition problem?
There is a switch that only only allows you to start the engine in Park or Neutral. It sounds as if yours is faulty or has a bad connection. Finding it will be the problem.
Jun 19, 2017 | 1997 Toyota Corolla
My 07 Toyota Corolla will start fine. It idles without problem, but as soon as I put it in drive it dies. 40% of the time it will do the same thing in reverse also. But 100% of the time once I put it in...
The engine uses an air flow meter and any vacumn leakages would cause the engine to shut off. I would suggest checking the air hose for leakages, hidden cracks that would only appear when the engine is shifted into reverse.
When in forward gears, the engine would tilt to one side, there are no leakages but when shifted into reverse, the engine tilts the opposite way, ( old engine mounts tends to allow the tilting to be quite substantial) causing the air hoses etc to open up any cracks and allowing excessive air to leak between the air flow meter and throttle body causing the stalling.
Hope this helps.
Sep 17, 2010 | Cars & Trucks
Engine overloads when shift to drive/reverse
check and clean your IAC valve, clean intake/throttle body. is your "service engine soon" light on??
Apr 28, 2010 | 2006 Chevrolet Trailblazer
Car will not start in park, but will start in neutrel. Car will die as soon as you put it in reverse.
have your neutral safety switch checked or adjusted. if engine dies as soon as it is shifted to reverse, does it so the same when you shift it to drive? if on reverse only, idle is set too low.
Jul 11, 2009 | 1991 Lincoln Mark VII
Transmission slipping,dies in drive
Hi there.Hope this can help.On the top of the transmission there's a black electrical plug that the shift linkage goes in..It sounds like the range sensor is out of adjustment..If you try going from reverse to like first or second does it still stall.You may have to get it adjusted.Does the selector in the car where it say P R N D 2 1 Line up with its indicator.
Mar 30, 2009 | 2005 Chevrolet Impala
Engine Died on Reverse Gear
try adding some transmition fluid to the transmition . or have it towed to a repair shop
Nov 12, 2008 | 2001 Mazda Tribute
Open Questions:
Computers & Internet Logo
69 people viewed this question
Top Extron Electronics Computers & Internet Experts
David Payne
David Payne
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
