Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Fahrenheat baseboard heater knobs
I am looking for the thermostat knob or dial for these heaters. I have several rental houses and the knobs with off, low, med and high, are disappearing. I don't need the metal piece is sits on. I'm looking for about 6 knobs. I do need the one square metal piece on the end that doesn't have the knob. heaters are tan. Can you help me?
  • Anonymous Feb 26, 2009
    need replacement knobs for fahrenheat thermostat at least 6 of them
  • Anonymous Mar 22, 2014
    Broken control knob for OFF-LOW-MEDIUM-HIGH Setting. Where can I get a replacement
  • 625 Answers
Go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Posted on Jan 10, 2008
No luck finding a new knob, but went to lighting department (Lowes) and purchased a two pack of dimmer switch replacement knobs. gently forced one onto the the heater and marked Lo, Med Hi with marker. Low cost solution. ($1.76)
Posted on Jan 16, 2011
    New Friend:
Hard to find, but they are available carrollparts.com 800-654-3545
Posted on Aug 31, 2016
Call Hande Davies
4-440-248-8383
Posted on Oct 21, 2011
  • Joe Valenti Oct 21, 2011
    1-440-248-8383
Maxiheat heaters oh107c
I replaced "Off - Low - Med - High" knob on Maxi Heat oil filled heater Model OH-107c with a Camco 00913 Knob (Purchased at Amazon.com for $7.03 including shipping - http://www.amazon.com/gp/product/B000KKOE4I/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1) - Blue insert fits snug - Had to remove 3 small tabs on cover that are related to 'stops' for original knob. Five minute repair and heater works again. (Side Note: I called manufacturer and they told me the heater had been discontinued for 9 years so they had no parts).
Oct 30, 2013 | Heating & Cooling
Need the switch for a maxiheat oh 107c
Apr 29, 2012 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
My son just bought a used Caloric self-cleaning gas range and the oven knob is high,med,and low. How does he know what the temp. is for setting the oven for baking?
Hi, It is the wrong knob. Do all the burner knobs look the same?
The oven knob has to have #'s on it so you know what hte temp is.
Please get me a model # and I can get you the part # for the knob you need.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water temp
The water heater thermostat control is usually under a plate/cover toward the bottom of the water heater. Remove the cover (first turn off the power to the water heater) and look for a dial with temperatures marked on it.
You can adjust the thermostat using its knob (if it has one) or a screwdriver. There may be insulation covering the thermostat, so you may have to pull some of that out of the way to see the thermostat.
Apr 29, 2009 | Water Heaters
Heat/ cool fan doesn't turn on -- 1999 Tarus Wagon
radio has 4 holes in front cover 2cloths hangers work well when cut to fit in holesinsert about 3 inches or until you feel springs release gently tug on hangers assembly comes out of dash
save time check heater relay underhood fuse panel
Dec 09, 2008 | 1999 Ford Taurus
Presto HeatDish
buzz? is this heater an infrared or are the heat coils exposed?
Oct 30, 2007 | Presto HeatDish Compact Heater
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
3,873 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
