Question about Mitsubishi WS-65809 65" Rear Projection Television
My 65 in mitsubishi medallion hdtv 1080 wont turn on green light flashes but will not turn off?
  • james w mcmeans
    james w mcmeans Jan 04, 2014
    my 65inch medallion hd 1080 screen jumps a little when i first turn it on then it clears up.
  • Mitsubishi Master
  • 5,138 Answers
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Posted on Nov 18, 2009
Testimonial: "excellent knowledge and communication! "
  • ladywinn
    ladywinn Nov 18, 2009
    Encompass Parts has listing for Tubes and what their Number Part number is you can look them up online or Call 1-800-638-3328 and heres another thing you could have a Bad HV high voltage trippler block Bad Part# 920P016010 Heres how to tell if that is the proble on your deflection Board the one that has your FBT flyback transfomer on it there will be 2 long wires coming out on it one will go to HV Block the other one goes to your Focus&screen control for the R/G/B tubes Pull out the one going to the HV Block MAKE sure you tape it away from everything, this is coming from your FBT if you have Nomal High Voltage thats what will be coming out of this wire Very High Voltage you do not want to get near it ,But if TV comes on and you hear sound that means that the HV Block is Bad. If you need any more Help let me know.
  • 66 Answers
Check for the settings and the cable that connects to the power supply
Posted on Nov 17, 2009
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
My 65 mitsubishi medallion 1080 hdtv will not power on
fault mentioned is not specific and so needs more clarification.
Oct 26, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green light flashes on my 65 mitsubishi 1080 medallion. reset button doesn't reset it and light continuously flashes
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
May 12, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
1,390 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
