Question about Casio Exilim EX-S500 Digital Camera
Having problems with the settings not being save and is being ask the same questions about language,world location,date and time every time i turn on my camera
SOURCE: Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Posted on Apr 09, 2008
mcomijohns
  • 477 Answers
SOURCE: Casio EXZ75 Camera
Your problem does not lye on any memory card. it is because the internal battery that helps the cmos "cameras internal memory" hold its settings has gone out and needs tobe replaced. all you need is 2 1.5 volt hearing aid batteries stacked and taped +-+- and soldiered in place of the old cmos battery. witch is located on the front side bottom close to the bottom left of the lens. and placed next to the speaker. get some small batteries to do this het smaller the better for placement location.Hope this helps I have done this to a few camera's and it works fine.
Posted on Apr 20, 2008
SOURCE: Camera resets when powered off
i have the same problem too, i think i pointed where the cmos battery is but i am not sure if it is the battery or not. when u open the door it should be to the right. it is not accessible til you open the camera. again im not sure if that is the battery. once i comfirmed. ill buy a broken one on ebay and swap it out.
Posted on Jul 24, 2008
  • 43 Answers
SOURCE: Date & Time loss with Exilim EX-S600
Good Morning :
Hope that you are wellJ
This is the response from Casio:
"The date and time will reset and the setting will need to be readjusted. The camera does not have a separate battery for the clock. The date and time will reset whenever the camera is not supplied power by the battery and USB cradle for about 24 hours."
Sounds a bit messy to me.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Posted on Sep 30, 2008
SOURCE: I have a new PowerShot
Replace this small battery near memory card:P it is hidden under a piece of plastic. it works like a battery on a mainboard - keeps clock alive.
Posted on Jun 18, 2009
How to set the date and time
Keep calm, dear.
Please moderate your language.
Look in the manual for the instructions.
Jul 24, 2017 | Again and Again Cameras
I NEED TO SET THE TIME AND DATE ON MY LEXMARK X5470 ALL IN ONE.
Set the printer to factory defaults. Caution you will lose all stored custom settings. You will then be prompted to set the language, country, date, time and time format, your fax number, and name on your printer..
You can reset your printer to the original settings by first turning off the power. Then p
ress the Start Color (green button) + X and keeping the buttons pressed down. Press the Power On button once to power the All-In-One on. Continue to hold the Start Color (green button) + X buttons for the next ten seconds.
When the prompt appears , release the buttons and follow the prompts on the display to choose your language, country or region code, date, time, and fax number.
Use the forward and backward arrows to select your language. Use the checkmark to save the setting.
Use the keypad to enter the date, time, fax number, owner's name, and press the checkmark after each selction to save.
For future reference support information for your printer may be found here.
Jan 21, 2012 | Lexmark X5470 All-In-One InkJet Printer
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Power on Set up
Somewhere on the camera it will list and ask which language you want, check english on the list. Good Luck
Apr 27, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
What is CTFMon.EXE and Can It Be Removed
1) Open the Control Panel2) Double-click on Regional and Language Options (if you are in Classic View)
or Double-click on Date, Time, Language, and Regional Options in Category View
3) Click on the Languages tab, then click on Details
5) Click on the Advanced Tab
6) Finally, place a checkmark in the box "Turn off advanced text services" and Click Ok
The language bar next to the System Tray should disappear, and CTFMON.EXE will unload from memory.
If you wish to bring back the language bar, simply follow the procedure above and UNCHECK the box to turn off advanced text services.
Microsoft has more information and a Frequently Asked Questions document about CTFMON.EXE, click on the link below to review it.
Frequently Asked Questions about CTFMON.EXE
Therefore, CTFMON.EXE is not a virus or a piece of malware, but its also not a program that you NEED running, expecially if you don't use Microsoft Office XP applications.
Oct 18, 2008 | Computers & Internet
How to set time & date on phone
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Thanks!
Mar 30, 2008 | Lands Phones
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Jun 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
20 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
