Question about Dell Dimension 2400 PC Desktop
Display comes on but goes off after a few minutes but works fine with another tower
  • 460 Answers
If you know how to do this it will be fairly easy for you.. pull out the memory sticks and clean the contacts with a pencil eraser or a fine wire brush and reinstall the sticks and this will resolve the display issue. with the 2400
Posted on Nov 17, 2009
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
My 2013 LG 42pn4500 plasma works fine until you change anything on the remote (volume, inputs, etc). As soon as you touch a button on the remote, the tv powers off for 5-10 minutes then comes back on....
Check the voltages goes to its display panel. Va & Vs voltages should be very accurate. any deviation to these voltages can cause unpredictable error symptoms with the set. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Televison & Video
Stand by link ON in Sony Trinitron KV-TG21L70 and display display disappears.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Televison & Video
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
When i cut on my monitor it goes out after a few seconds.The power is still on but it goes blank. Also when its on, the whole screen is a pink tint.my video card is fine i have duel monitors.but my wide...
tried self test on monitor unplug the data cable from the tower and turn on the monitor only ans see if the problem persist then u need to change the monitor if it works fine uninstall the video drivers and reinstall it or try onboard display if possible
Aug 17, 2009 | Proview PL19Wb Monitor
Dell Dimension 2400 PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
