Question about Microwave Ovens
I have a microwave hood combination.the problem is with the hood.i am using it in a recirculation installation.the intake has very little suction.it will just hold up a tissue.the discharge has a lot of discharge
  • 441 Answers
In re-circ mode it has two filters, one on the bottom, clean in sink, and the second behind the grill on the top, two screws hold in the grill, remove and replace charcoal filter and you should be fine
Posted on Nov 17, 2009
I purchased this microwave a few years ago but not until I bought a new stove did I notice that the exhaust fan does not draw the moisture up the chimney. The fan works, but nothing is being drawn up.
Jean, there's little information in your query, so I'll have to guess...
Many "microwave hood" combinations can be used as "recirculating" or as actual exhaust. It sounds like yours is set to recirculate. I don't know what make/model you have, but you might look in the documentation that came with it for how to switch it over.
Dec 22, 2015 | Microwave Ovens
Whirlpool microwave hood combination won't heat
There are three common issues, the magnetron "heats food" a cracked high voltage diode, a shorted high voltage capacitor.
Mar 10, 2012 | Whirlpool Microwave Ovens
MICROWAVE VENTALATION NO AIR INTAKE. MOTOR IS WORKING FINE.
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa
Jan 08, 2012 | Maytag Microwave Ovens
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Internal venting of KitchenAid Microwave oven hood combination
That info is in your installation instructions, which can be found here.
Jan 03, 2009 | KitchenAid KHMS105E Microwave Oven
Venting
I would suggest that you check the manual to be sure it;s set up right.
Then you need to check any filters that are in place.
You should also check behind the grille for any obstructions or dust, etc.
1. Unplug it from the outlet.
2. Remove any screws and unlatch any tabs in the vent grille.
3. Pull up and/or out to remove the grille.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Sep 28, 2008 | Whirlpool MH7155XM Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
