Question about Philips SA5125/37 MP3 Player
My phillips mp3 says {Memory corruption} wat does it mean
When my mp3 ran out of battery i got home and charged it then i was goin to play it and i would just pause at {Go Gear] then i got it to work from there but then it started to say (Memory Corruption repair now i say yes then it reapairs it then it says (Repaired All content cleared) i click it on "ok" but it wont do nuthing i already tryied the reset button and i connected it to my computer but it just shuts down then i have to disconnect it and reset it again but it just keeps on doing the same thing What can i do??
  • 8 more comments
  • analissa Jan 18, 2008
    How do I format my mp3 player?
  • J Mama Jan 19, 2008
    Same thing you turn it on and it says memory corruption repair now! you press ok it says repairing...... Repaired! All content cleared press ok, it shuts off. And you start again. Very dissapointed little 12 yr old boy, big alligator tears all night long, how do I format this thing your answer would be greatly appreciated.
  • Anonymous Jan 23, 2008
    Well, My didn't have charged at all, and I went home to charged it. But then when I got it to turn on; It said: that the memory was corrupted. and it took me through some things like clicking okay to repair. and I did but, then it came up to where it said it was repair and, I try clicking okay, and it wouln't do anything it was like if it was frozen.
  • 54gangsta Mar 02, 2008
    it says memory corruption repair now! i clik ok it says repaired!All content cleared! i press ok but it wont do go no were........
  • Anonymous Mar 03, 2008
  • carterd Mar 12, 2008
    the sames as the other guy about memory corpution
  • HAITI305 Mar 31, 2008
    ALWAYS SAY MEMORY CORRUPTION REPAIR NOW
  • HAITI305 Apr 01, 2008
    Memory corruption
  • Anonymous Apr 01, 2008
  • HAITI305 Jun 28, 2008
    when i turn it on it say memory corruption repair now then it says all content cleared then i turn it on then it keep on going
    Problem Solver:
  • 12 Answers
Format your mp3 Player then re-upload your music onto it
Posted on Jan 15, 2008
How do you format it?
Posted on Mar 10, 2008
I dont no wat to do with it and i dont no wat it meens
this is a 2G player for listening musicwith the headphones or on a audio system...You have to connect it to a computer to load mp3 files(music ) on it ..and after that it is capable to play them ..(to go )..
it uses either batteries or it has a built in battery that can be charged eiter with a charger or from the usb connection with the computer ..
Dec 21, 2010 | iLO (2 GB) MP3 Player
Bought ipod (white) 1 gig, from ebay .. will not play, will not start, just blinking lights. held play for 3 sec to get green light, still nothing, all controls only render orange and green blinking ......
Hi, problem can be solved. You need t look out for two things:
1. the battery of the i pod,
2. the memory of the i pod.
Checking the battery, the battery cell of the i pod might be too weak to power up the i pod, so you need to test with another battery before purchasing a new one. It may also need to be charged properly for longer hours before it can be able to power up the i pod.You can also check that out.
Checking the memory of the i pod. The memory of the i pod can also be the cause. Virus or corrupted applications can cause to malfunction.
After checking battery, if it does not work that means you will need to flash the i pod for the memory to be restore back to normal again.
Take care.
Apr 14, 2010 | Apple iPod nano
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
I have an 84 ford ltd crown victoria, charging ssytem wont charge my battery 4 some reason. ive already replaced the alternator twice, voltage regulator and the battery. cleaned the grounds, made sure all...
Dead cell in Battery? Take positive cable off battery while running and then it should stay running that mean the alternator is working. So you want to check battery out for dead cell in battery if that is the case it will not take a charge.
Nov 10, 2009 | 1984 Ford Crown Victoria
My sansa mp3 play wont turn on
Tried this? 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 05, 2009 | SanDisk Sansa e260 MP3 Player
How do you recharge the battery on the mp3
good day,
your mp3 player must come out of the package complete with its accessories and, of course, a battery charger. just plug the charger on its appropriate socket in your mp3 player and plug it on your wall socket.
just follow the suggested number of hours for its initial charging and after that you can just check if it indicates "battery full."
i hope this helps
Oct 12, 2008 | Audio Players & Recorders
Mp3 won't charge or turn on
Press the A/B and Menu buttons together to reset.
Jul 17, 2008 | Samsung YP-U3 MP3 Player
Mp3 not playing thru phillips micro - mcm239d
Philips hifi systems only support flash memory sticks or MP3 players which show up as flash memory sticks.
SA5125 is not compatible
Feb 17, 2008 | Philips SA5125/37 MP3 Player
Wont charge and memory corrupt even after i reset tons of times
Plug your MP3 Player into your Pc and Format The removable Drive Then Re-load your music onto it if that doesn't work it'll have to be a hardware problem my only other suggestion is get out your Guarantee and send it in
Jan 15, 2008 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
428 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
