Question about Asko 24 in. D3121XL Free-standing Dishwasher
Machine not starting , door not closing well, no click from locking mechanism
    Novelist:
  • 154 Answers
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Ash
Posted on Nov 17, 2009
Locks but won't start
Go to repairclinic.com bring you make and model number. See the repair help. It will tell you what is wrong. It may list more than 1 possibility.
Apr 22, 2015 | Maytag Washing Machines
The front door won't close, due to washer lock mechanism restricting door close.
Thank you for your inquiry, kh57ca!
From what you are describing it sounds like the door latch assembly needs to be replaced. This is not a simple DIY job though. I would recommend seeking guidance from a professional technician to properly replace the door latch to avoid any future issues. Some of these intricate parts require precision and patience, therefore when replacing such components or removing them from your appliance, I would suggest seeking professional assistance. I hope this has been beneficial. -Matt
Oct 12, 2014 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
RE: Miele dishwasher G1472 The door will not close. Does the lock work with a relay, or is just the plastic lock broken down? I should like to have a repair manual of this machine. Where can I find it?
Sorry mate - manuals are hard to come by from miele, only service agents have these and are bound by contractual obligations.
there is a door locking plate located mid top of the dishwasher which latches to the door, a locking mech. # 6022271 located on the door itself.
The locking mech is electrically controlled only when cycles are selected and you push start. The chances are where the latch system which clicks into the mech is likely to be worn or jammed, the door should click into place as you close it and electrically locked during the cycle.
I would say there is a mechanical problem with the machine more so than anything else.
Jul 04, 2011 | Miele G 1472 SCVI 24 in Builtin Dishwasher
Re: Maytag Neptune Washer. Loaded 2 jackets (whites requiring bleach), added usual Gain detergent (granules), plus small amt. of bleach in dispenser, then started cycle. Then poured bleach into machine...
DO = Door Open
Door monitor switch in door lock mechanism is not able to communicate to the control board is open.
1.Make door is closed.2.Check for loose wire connections at switch and/ or machine control board.
3.Check for failed door monitor switch.
4.Check inputs and outputs at machine control board.
FL = Failed To Look
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
Dec 31, 2010 | Maytag Neptune Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Door won't lock
If the interlock isn't working it may not allow the machine to start. If you can open the door when it should be locked it's probably a faulty interlock.......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door lock mechanism
I had this problem also with my Maytag Neptune TL. The door lock would click muptiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure eaither that or sandpaper will do. After that it went through the whole cylce without stopping or displaying the "FL" code.......hope this helps
Jun 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Asko 24 in. D3121XL Free-standing Dishwasher Logo
266 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
