Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
How can i put on the snap ring on an eloctolux vacuum hose on the end piece of the hose; it is a swivel end and an older vacuum cleaner plastic canister type
  • 430 Answers
The snap ring is generally found on a Canadian made LUX AP series prior to 1982 and it is in fact a coil spring you must leave the wiring off the handle. Be sure the steel cap and rubber o ring are on the tip of the hose. Slide the handle onto the hose with the hose tip facing upright. then with a small flat screwdriver separate the hooked tip of the spring from its body and run your screwdriver around the spring,feeding it into the groove inside the hose handle, spiraling as you go. similar to how you would feed a key onto a key ring. Before inserting the wire cover try to swivel thew handle it should rotate smoothly. Be very gentle inserting the wire cover pin as it will crack the handle. Use gentle pressure with pliers to start it , then squeeze it into place with your plier jaws fully open.
Post back to advise how you have made out
Posted on Dec 17, 2009
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Aug 08, 2016 | Riccar Vacuums
Replacing riccar 4812 hose
To replace just the hose unscrew it from the swivel attached to the back of the vacuum. The replace swivel insert screwdrivers into the tabs holding it to the body (from inside the dust compartment) to remove it, the new one snaps into place.
Jan 03, 2014 | Riccar 4812 Vacuum
Hose attachment
Not sure if you're referring to the wands or the swivel neck?
Here are 2 examples, if these help then great, if not then can you give more information?
http://tinyurl.com/grey-wands
http://tinyurl.com/grey-neck
Nov 06, 2013 | Electrolux Lux 5500 Canister Vacuum
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
I bought a new plastic end piece for the hose but can't get the old one off the hose to change it???
Soak the end of the hose it very hot water to soften the end of the hose. Then insert a screwdiver inside the plastic end piece and flex the end of the hose inward and pull the old end off. To install the new end, bend the end of the hose into a "kidney bean" shape and push the new end on.
Jan 02, 2011 | Kirby G6 Bagged Upright Vacuum
I have a Bissell 1690 carpet cleaner and it is leaking water very quickly out the back. How can I fix this problem?
I had the same problem with my bissell proheat carpet cleaner. My cleaner would leak water out the back when i turned it on. I opened up the cleaner and found there was a broken tee connector. The tee connector was a small black plastic three way connector shaped like a letter "T" with three plastic hoses plugged in to each end. One hose had broken off from the tee, the tee connector itself had snapped. Bissell has a couple hoses that run up through the upright porsion of the cleaner, i believe if that hose gets pulled too hard by over extending the cleaner upright portion it can snap the tee connector.
I purchased a vacuum line tee connector at the local auto parts store for a buck and replaced it. The vacuum line connectors are for rubber lines on a vehicle related to the engine, but they work fine for the Bissell. The size i purchased was 3/16"x3/16"x3/16". The cleaner works great now!!!
Here is how i took it apart:
I removed the water reservour, the soap dispenser, and the cap for the air flow indicator (red spinny thingy).
I removed the two screws in the very back, the two in the middle on each side of the water resevour and the two in the front. I carefully lifted the top of the cleaner off.
Inside you have to watch for a black plunger piece that might fall out, it belongs to your (heavy traffic/light traffic/water only) turn knob. If the plunger falls out reinsert it back into the underside of the cleaner lid right next to the knob, you will see how it fits in there...hopefully. Inside the bottom portion of the cleaner you will see a few hoses. Check them all and make sure none of them are disconnected or broken off from the tee connector. I would almost bet that this is what your problem is if the machine is leaking. replace the valve, reconnect hoses and carefully reassemble the cleaner.
Hope this helps...
Jun 25, 2010 | Vacuums
How to replace just the Kirby 210097 Hose End For G5 Series Vacuum Cleaner to hose. can buy replacement but can not get the broken end off
simple and rquires no tools. Fill your sink with hot water and set the end in water with attachment on it. Within a few minutes the end is soft enough to slip out.
setting the hose end in the water again will let you simply slip the hose into the new attachment with ease.
Nov 24, 2009 | Kirby G5 Bagged Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Won't power on.
It maybe cheaper by going to somewhere like the Radio Shack to get a fuse. Take the bad fuse with you and they should be able to fix you up with one.
Jan 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
96 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
