Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
How do I get the lid back on the toilet?
How do I get the lid back on the mercerator sandiplus toilet?
    Sergeant:
  • 399 Answers
Lightly grease the rubber seal first this will help you slide it into position thats the hard bit now you can fit the lid remenbering to tighten corner to corner so that you get an even pull down
Posted on Nov 17, 2009
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a 1 yr old new Danze Orrington two piece toilet. DC013230-DC012223. I have 3 of the same actually but only one is giving me problems...the one on the first floor of the house. The flush is weak...
Your thought is probably correct. Usually toilet tank lids and feet on them to allow air enty. You might have to add rubber feet (self adhesive) or balance the lid on the tank differently.
Jun 03, 2011 | Danze - Toilet - One-piece - Orrington -...
Installation of lid seal
Typically the lid seal has an opening all around the center and it must face up and fit inside the lid, once is fitted inside the lid cover, lubricate the bottom of the lid seal with soapy water and place it on top of the pump casing. Then apply pressure at the side tabs to snap the lid back in place, note that you may have to use a big C-Clamp to be able to put the lid back on.
May 21, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
I can't get the lid back on because of the seal. Can you help?
The lid seal has an opening all around the seal. Make sure the opening faces up inside the lid, there is a groove inside the lid where the lid seal sits in place. Once is placed correctly on the lid, lubricate the lid seal with soapy water and then place on top of the pump casing and just put pressure on the side tabs so it snaps in place. Note that sometimes is required to use a C-Clamp to put the lid back on.
Aug 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
388 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
