Question about Westinghouse TX-47F430S 47 in. LCD TV
My Westinghouse 47F430S suddenly has no picture, but the sound still works. Does this sound like a light bulb issue? A circuit board issue? Any thoughts on how to fix it?
  • 120 Answers
Hello, this is an inverter board issue which is the board that powers up the backlight. There are two places that will most likely have these two boards (master and slave) available and they are www.shopjimmy.com, and www.invertercentral.com, you can alos send an email to me at westytech@wde.com if you would like to troubleshoot a bit more or just to obtain a bit more information on this model. If this information has been helpful please rate my solution.
Posted on Jan 27, 2010
  • Vpm1 Apr 30, 2012
    Hi, how do you test the boards. there are two, master and slave. replace both?
My westinghouse "46 wont turn on...is it the power supply and can I replace it
It sounds like the power supply is having an issue. Yes its easially replaced no special tools required just a screwdriver. You can get the power supply board from www.tvcircuitboards.com
Feb 10, 2013 | Westinghouse TX-47F430S 47 in. LCD TV
Tv has no picture only sound
the inverter is the usual cause of that issue, some westinghouse models have the inverter combined with the power board. You can get the replacement board and free tech assistance from www.tvrepairworld.com
May 16, 2012 | Westinghouse Electric Televison & Video
Screen turns on for two seconds, then goes blank. Sound is still on, tv is still on.
This problems are the causes by those 2 long boards to it right and it left call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Nov 26, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Need to replace fuse in the power supply board. can't get the old fuse out.
The picture relates with your board. Your need to de-solder the heat sink cover to get access to its fuse. Open it carefully and replace the fuse.
good luck
Feb 02, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
No picture from dvd when using hdmi cable
make sure tv is on correct source for that hdmi input.
Jan 27, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Westinghouse TX-47f430S Will not power on. LED power indicator flashes blue then to red. Found some fluctuating voltage in the PS and replaced a ceramic cap and it cleared up part of that issue, but it...
There are some bigger electrolitic caps in the power supply that can cause this problem also. Testing with a ESR meter while they are in circiut doesn't always work, they need to be taken out and tested with a cap checker.
Sep 01, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
Screen scrambles into various colors and freezes
TV requires main board replacement because problem seems in video processing section.
Main board is available at Shop Jimmy on reasonable price. (click shop jimmy link to see an image of main board)
Jun 02, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
333 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
