Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Where is the Fuel pump relay located on my 2004 Dodge ram 2500 Diesel?
  • 106 Answers
Under the hood by the fuses
Posted on Nov 17, 2009
Where is fuel pump fuse and relay on 2002 dodge ram 2500 diesel?
There is a fuse and relay under the hood on the drivers side right above the front tire. Open the fuse access cover and look in your manual to find the fuel pump fuse and relay if it is not listed on the underside of the cover.
Jun 30, 2014 | 2004 Dodge Ram 2500
I changed both batteries on my 2004 Dodge Ram 2500 Diesel Cummins and now my electric fuel pump relay repeatedly clicks and the engine won't start. The fuel pump was retrofitted by the dealer...
sounds like a ground may not be rite--also chec the plug into the pump for corrosion--relay cud be bad-test it--ask a parts person where you bot the scanner to help you
Dec 17, 2010 | 2004 Dodge Ram 2500
Where is the filter located on a 2001 dodge ram
2001 Dodge Truck RAM 2500 3/4 ton 4WD 5.9L Turbo Diesel 6cyl the Fuel Filter is located under hood, passenger side, lower engine area, mounted above starter.
2001 Dodge Truck RAM 2500 3/4 ton 4WD 5.9L SFI 8cyl the Fuel Filter is located under vehicle, center, below seating area, mounted on top of fuel tank, in fuel pump module.
Hope helps with this (remember rated the help).
Jun 01, 2010 | 2001 Dodge Ram 2500 Truck
Looking for the fuel pump relay fuse on a 2004
Check your owners manual. 2 Places. Under hood AND Left side of dash on the end, visible Only with drivers door open.
Nov 30, 2009 | 2004 Dodge Ram 2500
Where is Fuel Relay for 2004 Dodge Ram 3500 Diesel Truck
it doesn't have a fuel pump relay it has a fuel pump control unit and it is located on the chassis back quarter drivers side near the tube cross member for chassis on top of chassis rail near bed mount. locate the rear springs front perch and it will be above that on top of rail.
hope this helps. good luck and please ask any question you have.
Oct 25, 2009 | 2004 Dodge Ram 3500 Truck
99 dodge diesel wont start
Check the fuel pump relay, you can swap the fuel pump relay with a similar one under the hood, swap it and check power again.
Please remember to rate this answer.
Feb 11, 2009 | 1999 Dodge Ram 2500 4WD
do you still have the old style lift pump. located on the fuel filter housing or has it already been updated to in tank style. sounds like that to me. i've done a ton of them. chrysler has a whole conversion kit for this mod
Jan 08, 2009 | 2004 Dodge Ram 2500
2004 dodge ram 2500 5.9 diesel hard to start
The lift pump is bad Check the fuel pressure with a test gauge.
Jan 04, 2009 | 2004 Dodge Ram 2500
2004 DODGE RAM 2500 DESIEL
the transfer pump is going bad ...dodge has an intank replacement for your vehicle
Nov 11, 2008 | 2004 Dodge Ram 1500
2004 dodge 2500 diesel
relay has gone bad replace relay should work.
Sep 20, 2008 | 2004 Dodge Ram 1500
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
219 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
