Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Printer does not take paper
There was paper jam I forcibly took paper out after this printer does not take paper
  • 62 Answers
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Posted on Nov 17, 2009
Canon Pixma MG 3200 is showing error code 02. I have reloaded the paper 20 times - no joy - stilll error code 02 - Any ideas?
remove jammed paper stuck inside the printer slowly, and u should be up to go
N.B do not pull the paper out forcibly from the front tray as this may cause serious damage
if u dont find any paper inside try to clean what ever it stuck inside the printer and be careful
Mar 22, 2017 | Canon Office Equipment & Supplies
Keeps saying paper jam,but no paper jam is inside
The jam indication is set because the sensor(s) detect one. This could be due to a buildup of paper dust, a small bit of a sheet that tore off and got lodged deep inside when removing a previous jam, or damage to the sensors if the jam was removed forcibly by pulling the sheets out from the wrong direction.
Dec 10, 2015 | Brother DCP-7020 All-In-One Laser Printer
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam at ML-1915 - SAMSUNG
Dear
Pl. clean with dampen cloth, to the separation pad on the paper tray and the pickup roller bellow the printer base and above the paper tray.
do not forcible rotate the pick up roller.
Thanks.
Jan 18, 2012 | Samsung Office Equipment & Supplies
I had paperjams and i pulled out the paper from the front of the printer. I have done this more than once. I then found out recently that it was best to remove the back and pull ot the paper. Could...
I always recommend that paper jams be removed in the direction the paper would normally travel. Forcibly removing jams generally will not damage rollers, as the hardware tend to cause paper to tear before anything breaks. Removing paper jams in the wrong direction however can break one-way "finger" paper path sensors occasionally. If you are not experiencing a jam every single print, you are probably in good shape.
As for cleaning the rollers, if you have taken the rear door off the printer you are halfway there. You should be able to turn the rollers in one direction or the other by hand. There are plenty of products out there to clean rubber rollers (I use Blow-Off Rubber rejuvenator) but rubbing alcohol on a cloth can work as well. Turn the rollers to get at the entirety of them and scrub along the length with an alcohol dampened rag.
Jun 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
The 8 1/2 x 11 paper tray will not open - it is not jammed with paper as the print still prints, but we cannot dislodge the tray.
You need to forcibly open the tray, that's the only way. It could be the feed roller assy is gettin hung up.
Dec 23, 2009 | Ricoh Aficio 1013 All-In-One Laser Printer
Says it has a paper jam but there is no paper in it!!!!
Often there is a small piece of torn paper in the vicinity of the paper sensing switch lever.
OR the switch lever has been damaged by forcibly removing a paper jam.
You should open the printer and inspect the paper path for these problems.
Sep 01, 2009 | Dell V305w All-In-One R840635AU InkJet...
Printer shows a paper jam when there does not appear to be one
Often, even after you have removed the paper jam, one of the sensors can still report a "Paper Jam". These sensors look like small plastic "fingers" that project along paper path. More sophisticated printers may have an "electric eye" mechanism. Sometimes when you get a bad jam, the paper has to be ripped out, and a very small piece can get caught on one of the sensors or block the electric eye type sensor. Remove the ink cartridges and shine a light into the machine and look for small pieces of paper stuck inside, and gently remove them. If one of the sensor fingers is bent or jammed, it can cause the same problem. See if any of these are stuck and gently free them. Take care, since they break off very easily. They may also break off if you forcibly pull out a jammed paper. If one of the sensors is broken, then you are out of luck, and will need to buy a new printer. you can also try vaccuming insides with one of those flat nozzles connnected to a regular vaccum cleaner.
May 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Misfeed error
1. Check that absolutely no paper is jammed within the infeed paper sensors. Sometimes a tiny piece of paper will get stuck in the sensor after a jammed sheet has been forcibly removed.
2. Use a can of Dust-Off or similar compressed air product to blow the paper path out. Paper lint can block a sensor.
Feb 23, 2008 | Ricoh 6513 Copier
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
old marine
old marine
