Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Needs new motor have the part but cannot get into the part of the hoover where the motor goes
  • Dyson Master
  • 379 Answers
Have a look at www.dysonmedic.com.
Posted on Dec 01, 2009
Where is the thermal protector sensor on hoover vac.
On most vacuum cleaner models it is built into the motor and cannot be changed without replacing the motor. In my experience the reset switch goes bad more often than the motor does which is why I recommend vacuum cleaners that have an external reset switch.
Jan 05, 2017 | Hoover Vacuums
How to replace belt on hoover SH40060
You have to remove the roller to get to the belt' look at the face and bottom to find the screws that hold the plate that covers the roller. Take the plate off and look @ the roller, to see where the belt runs. then take the roller out, you should be able to see the pin shaft that comes from the motor,the belt goes around it and over the roller.Be patient putting it all back together,and don't over tighten the screws, they strip easily, Good luck!
Feb 20, 2015 | Hoover Vacuums
I need a repair manual for a Hoover U5753-900?
Google Hoover vacuum manuals....consider this...how much will a
motor cost? How much will a new vacuum cost? I point this out
as I have no idea of what kind of vacuum you have.
Regards.
Dennis
Aug 19, 2014 | Hoover Vacuums
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
How do i install belt?
every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
Apr 04, 2009 | Hoover U5081-930 Turbopower 3000 Bagged...
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
How do I install the belt in a Hoover dimension II vaccuum?
Take off the bottom plate, then you can get to the brush roll and the belt. The belt goes around the brush roll and goes to the motor shaft. If you can't see the motor shaft, then you will have to take the top cover off to get to it.
Jun 14, 2008 | Hoover Vacuums
Replace Powercord
It has a cord relief to hold the cord in near the bottom, you will have to pull that out, the cord goes in there and comes out by the motor where the the wires connect. So you will have to pull the motor cover off to get to where they hook up to.
Apr 15, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Windtunnel
If it goes in just at the bottom of the handle, take off the handle, then remove the tool holder, then you can replace the cord. If it goes in near the bottom, then you will have to remove the motor cover and light to get to the connecting wires.
Oct 11, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
48 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
