Question about Bosch Integra 300 Series SHX43C0xUC Built-in Dishwasher
I DONT THINK WATER IS GETTING TO MY DISHWASHER
  • 366 Answers
Is there water in the machine if you open it when running? if so the water is coming to the machine, if not, check if the tap where it draws water from is open,
Posted on Jan 16, 2010
Hello, I recently installed a new faucet in our kitchen, hence turning the water. Not aware that my wife tried to wash dishes in the dishwasher before i turned the water back on, i think she damaged our...
Without a brand and model number, here is my best thoughts on what to check;
1) Was the shut off valve for water going to the dishwasher turned on after new faucet install? Is it turned on now?
2) Is water getting to the dishwasher water inlet control valve?
3) If water is getting to the water inlet control valve, unplug the dishwasher and check the solenoid to see if it is shorted. Unplug the solenoid. Using an ohm meter, check for 500-1000 ohms resistance. If there is no resistance, it is most likely shorted and needs to be replaced.
Sep 05, 2011 | Kenmore Dishwashers
I don't think the water is getting as hot as it used to in my Ariston dishwasher. Our hot water heater is set high enough, but when I tried one of the dishwasher cleaners, the plug did not disolve as...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2011 | Ariston Technologies Dishwashers
I have a LG 6lnd0920, I don't think it is getting any water. The tech that the insurance company sent out says it is the water pump and wanted almost 500 bucks to fix it. Can I buy a pump locally and...
you can buy the parts yourself, i dont know about locally, but you can go to sears parts website or repaire clinic,, replacing the pump is about a 6 on a 1-10 scale 1 being really easy,, you will have to take the dishwasher all of the way out and lay it on its back, then remove the bottom panel, but if it is not getting water it might be the water valve,, turn it on and let it run for about 3-5 minutes then open the door you should see water, if not make sure the water valve is turned on and your water ilne is not pinched,, if all is good you have a bad water inlet valve
Jan 19, 2011 | LG LDF6920ST Stainless Steel 24 in....
Water line attachment
better to safe then sorry . pull out the unit and connect correctly. you dont want to think about it may leak because if leaks it could flood. if i have helped in any way please give me a 4 thumbs up post thanks
Feb 28, 2010 | Dishwashers
I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not being pumped into the machine
Mineral buildup in the water lines may have broken loose when the boiler (I really think water heater) was replaced and clogged the line somewhere between the boiler and the dishwasher.
Your boiler installer can come out and check that for you.
Jan 16, 2009 | Dishwashers
Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Jan 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Asko d3250
First I would check the water line from the sink that is hooked up to the dishwasher.
You may have a screen that plugged up.
Also, if you have little pressure at your sink faucet, then you should check your house's water system.
Mar 04, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Bosch Integra  300 Series SHX43C0xUC Built-in Dishwasher Logo
103 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
