Question about GE Security Simon 3 Wireless Home Security System
When I plug in GE Simon 3 panel it is already armed
When I plug in GE Simon 3 panel it ia already armed and I have no access code to stop it. Factory 1234 does not work.
    New Friend:
    Problem Solver:
  • 10 Answers
You need to default it
Posted on Apr 25, 2013
Is your Simon 3 new or used? The default Utility Access Code 1 or 2 (i.e. the code you use when you open up the cover) is 654321, 54321, 4321 or 321. The default Master Access Code (i.e. the code you use to arm / disarm without opening the cover) is 123456, 12345, 1234, or 123. The length of the code depends on option 54. Default is 4 digits. If it's a used one that has non-default settings, you can reset memory to factory defaults.
Posted on Nov 19, 2009
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
Don't know access code. Bought used control panel
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the
transformer while pressing these three buttons. The
panel announces “Hello. System XX OK.” Release the
buttons.
5. Connect the remaining power source to the panel.
- AlarmProfessor.net
Jul 16, 2010 | GE Security Simon 3 Wireless Home Security...
GE Simon - Reset Installer Code & Remove Sensors
I am sure you already guessed this but it appears someone has changed the default installer code. Using the default installer, dealer, or master codes defeat the purpose of a security system as most criminals know the default codes. The only way I know of to regain control of this panel is to reset it to factory defaults. This does mean that you will have to completely re-progam the system. I would document as much stuff as you can from the display before resetting it. If you don't have a copy of the installation manual I am providing a link below. Hope this helps.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
I am trying to figure out how to use the remote phone access feature for my GE Simon 3 system. I want to call my panel to arm, disarm or check the status of my system when I'm away from home. ADT keeps...
ADT has there systems custom made for them. so they may have dumbed down the system so they dont have to spend there time helping with problems.
most system usr the ring hang ring method.
you dial the the number that your system is connected to let ring 1 to 2 timen hang up wait 20 seconds call back the panel should answer then follow your instructions. most panel will have you press somthing like *** them the panel will tell you to enter your access code. then the panel will walk you thru the rest.
mj
Jul 29, 2009 | GE Security Simon 3 Wireless Home Security...
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:
https://portal.gesecurity.com/portal/login/login.jsp?TYPE=33554432&REALMOID=06-0008ce40-a18c-1536-85ea-8312f762000e&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$https%3a%2f%2fportal.gesecurity.com%2fportal%2fmdme%2fDownload.jsp%3fID%3d320%26DID%3d320%26documenttype%3dInstallation$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
Problem about remote access by phone or cell phone
You have the right info are you using the master code?
How to gain access to the Control Panel:
1. Call the panel and let the phone ring twice then hang up.
2. Wait at least 10 seconds and call the panel again. You may wait up to 40 seconds
before calling again.
3. The panel should answer on the first ring. You won’t hear any prompt when the
system answers.
4. Press the * button on your telephone and you will hear system activated.
At this point you may perform the actions listed in the following table of phone commands.
CODE refers to the master and access codes programmed into your system.
also contact your installation company to see if this feature is enabled.
mj
Apr 21, 2009 | GE Security Simon 3 Wireless Home Security...
GE simon 3 security system How to reset master code?
The default master access code is 1-2-3-4, try it to see if this works.
Apr 15, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
We have a simon 3 panel and were wondering if it will auto-arm?
you can get the installation manual here.
Dec 05, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
593 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
