Question about Canon BubbleJet i320 Printer
Printer lights go green and amber, it doesn't print all it says is the printer is busy in the status monitor. all maintenance icons doesn't work.please help.
  • Sengele Andi May 11, 2010
    when you look at the user guide, wht does green light refers to? Did u ckeck the paper jam? Try to remove the catridge and then restart the printer. Let m know
I am having the same problemm..did you find a solution?
Posted on Dec 15, 2009
All lights flashing on the printer
1. Go to Devices and Printers
2. Right click your printer icon
3. Select printing preferences
4. Click maintenance tab
5. Click Epson Status Monitor
If the show service required then your printer counter needs to be reset. Go to nearby Epson service center and have them reset your printer counter.
Nov 30, 2013 | Epson Expression XP- 202 Inkjet...
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
switch.
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
again.
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
required.
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
My Zebra 2844 light won't stay green
The amber light means the cover is not closed all the way. Something is preventing the cover from staying latched closed - it's releasing just enough to activate the cover-open sensor. Maybe check if you can see anything broken where the cover latches shut.
Not sure if this will be too helpful...
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
How to clean printer heads
You can try and clean the printer head by holding down the maintenance button on the printer control panel for three seconds.
If that doesn't work then make sure the red light is off. If it is blinking, check the cartridge to make sure there is nothing wrong with it. Otherwise, either right click the status monitor 3 icon in the windows taskbar and select clean head, or on a Mac use the print utility.
When the green light stops flashing run a nozzle check.
If the nozzle check gives you 4 clean boxes your good, if they are grainy or lined rerun the cleaning. You may have to run this several times and the cleaning uses a lot of ink, so be prepared to replace the ink when it is all over.
Dec 09, 2009 | Epson C64 InkJet Printer
How do I clean the printer heads on epson c 60 printer
Dec 07, 2009 | Epson Stylus C60 InkJet Printer
GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Epson r260 status monitor wont show up
Try these steps ::>>
Go to Control Panel / Printer and Fax and then right click on the
R260 printer icon / from the options left click on printing preferences /
on the Printing Preferences window click on Maintenance Tab / on the
lower right click on the Speed and Progress Tab / on the Speed and Progress window there are check boxes look and see if the box for the Disable EPSON Status Monitor 3 has a check on it ( if it has a check., remove it )
Apr 04, 2009 | Epson Stylus Photo R260 InkJet Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
Canon BubbleJet i320 Printer Logo
410 people viewed this question
old marine
old marine
