Question about Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
Hearing a scratching sound while drum is spinning...sounds like something is scraping it?
  • 441 Answers
Its one of two things 1. something is stuck under the lip of the drum,like a dime or paperclip. Fell all around the lip of the drum and you should feel it. 2. your Bearing Glides are worn down, they run about $5 each and yours has four of them, you will need to pull it apart to change them, its not to hard to do yourself
Posted on Nov 17, 2009
Testimonial: "it appears to be #1 as whatever was causing the noise disappeared (could not feel anything) so that should rule out the bearings. phew!! TY"
Can I safely use my washer if I hear something metal scraping during spin cycle?
You can, but I wouldn't. The outer skin of the drum is made of plastic. If it is a coin, it could dislodge, get caught again in mid spin and punch a hole straight through the plastic.
Get a flashlight and look between the seal and the outer drum when you open the door.
Jan 24, 2016 | Frigidaire Washing Machines
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
Hello my Wirlpool washing machine makes a scratching noise when the drum is turning during the wash. The noise disappears however when the washing machine is spinning. Would it be worn out bearings?
You would hear the bearings in the spin cycle if it was them ....it would sound like you are at the airport...you will probably find that a bra wire has caught itself inbetween the drum and the tub and is scratching as it goes around.
Nov 11, 2010 | Washing Machines
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer Logo
230 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
