Question about Norcent Technologies PT4231 42 in. HD-Ready Plasma Television
My Tv is stuck in mute. When ever I accidentlly press the info and c button on my AT&T remote this happens, normally I can go to the menu button and click sound and then external and then internal and I have sound. Now I am stuck in mute
Tip
Service menu codes jvc
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Turn the TV on.
Using the remote control:
- Press the {INFO} & {MUTE} buttons at the same time.
- The Service Menu will be displayed
- Use the number keys to select the category.
- Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don't have category selection.
- Use the {CH+} {CH-) buttons to select item to be adjusted.
- Use the {VOL+} {VOL-} buttons to change values.
- Press the {INFORMATION} button to exit.
Turn the TV on.
# Press {DISPLAY} & {PIC MODE} buttons at the same time.
# The Service Menu will be displayed
# Use the number keys to select the category.
# Use the {UP} {DOWN} buttons to enter a category.
# Use the {LEFT} {RIGHT} buttons to select items.
# Use the {UP} {DOWN} buttons to change values.
# Press the {DISPLAY} button twice to exit
# Press the {MENU} button.
# Select "Clock Set".
# Set clock to 3:21 AM and press "Start Clock".
# While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
# The Service Menu will come up.
# Use {UP} {DOWN} to select items.
# Use {LEFT} {RIGHT} to change values.
# To exit, turn the TV Off.
on Apr 29, 2015 | JVC Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
APEX LD4088 service menu (advanced menu)
Try this:
  • Turn the TV off.
  • Press and hold the {VOL -} button ON THE TV and
    the {TV/VIDEO} button on the remote for at least 5 seconds.
  • The TV will turn on with the Service Menu displayed.
Here's how to access the SM:
  • While the TV is in standby:
  • Press the {DISPLAY}, {5}, {VOL+} & {POWER} buttons.
Nov 29, 2014 | Apex Digital LD4088 LCD TV
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Norcent Technologies PT4231 42 in. HD-Ready Plasma Television Logo
62 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
