Question about Logitech Harmony 890 Universal Remote
Logitech harmony 890 fails to change channel or pull up guide. Will turn on television and adjust volume, but all other commands do not respond.
    Novelist:
  • 76 Answers
Did the behavior of your remote change or have you just started using the remote? If this is an initital setup, ensure that you have selected the correct model numbers and that your setup configuration is correct in the Logitech software. Many problems have been resolved by going back to the software configuration and making sure that all of the devices and mappings are correct. Assuming the programming is correct and things were working properly at one time and no longer are then you need to determine if the issue is a physical problem with the button activation (key presses are not making contact), or a software problem (corrupted programming). So here are some things to look
for:
When you press a key, do you see the 'transmit wave' icon appear at the top of the LCD screen? If so, then the remote is registering the key press. This means that the physical operation of the button is ok, so in this case, your issue is probably firmware/software related. You should update the remote's firmware and then re-load your settings. Both of these procedures are done using the Logitech software. If, after doing
a refresh of your firmware/software, there is still a problem, you can try mapping some of the hard keys to 'soft' keys on the LCD screen. So, instead of using the "Guide" button, you have a "Guide" option on the screen. The link below will explain the process for re-mapping button functions (it describes the process for the 880, but it should be the same for the 890). Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9796&p_created=1232640364&p_sid=1E1TzrCj&p_accessibility=0&p_redirect=&p_lva=3219&p_sp
Posted on Mar 06, 2010
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
Tip
Harmony 890 Pro Manual Download
Download Logitech Harmony 890 Pro Remote Control Manual
Have you misplaced your Logitech Harmony 890 Pro Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Pro Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Televison & Video
Tip
Harmony 890 Manual Download
Download Logitech Harmony 890 Remote Control Manual
Have you misplaced your Logitech Harmony 890 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Remote Control Users Guide?
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 Universal Remote
My harmony remote won't change channels or do anything. It will only change the volume. Why?
Hi. There are a couple of things that you can try to get the remote working. First, you can learn the commands from the original remote for your devices.
Also, ensure that the buttons on the remote are properly mapped to commands. You can check your button mapping my clicking "Customize Buttons" beside the icon for your Activities.
Hope that is helpful.
-D
Dec 06, 2009 | Logitech Harmony 890 LCD Remote Control
Tip
I hope that helps.
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Can not change channel with 890 remote. Volume button works. Ca turn tv on and off with remote just can not change channels
Hey!
You might have to make sure your Harmony remote has the buttons customized right. The following link shows how to do it!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9700
If it still is not working, you might have to learn the commands. The next link shows how to do that:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9603
Hope this helps!
-Kennedy
Sep 28, 2009 | Logitech Harmony 890 LCD Remote Control
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony MAC Software Download
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 Universal Remote Logo
162 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
