Question about Cnet CWR-854 Router
I cannot connect with the Internet. The phone
I cannot connect with the Internet. The phone lines are dead in the neighborhood. Would this have anything to dowith it?
  • 481 Answers
If your internet connection is over DSL, yes, certainly it would. If your internet connection is cable, the phone outage shouldn't have anything to do with it.
Posted on Nov 17, 2009
Testimonial: "Thanks for the immediate reply to my question. I appreciate it. The answer waswhat I nee4ded."
My land line is dead for 4 days. My network is working but my phones are dead unbelievable but tru
problem here
if you have a copper land line then the adsl is working to be on the internet
that means that there is not a problem with the land line as both telephone and internet work through the same copper line ( different frequencies)
so that indicates that the connection at the wall for the phone is faulty, or if you are using noise suppressors as recommended on the phone line in the house , that unit may have failed and not letting the phone frequency through
which ever way , if the technicians test the line and find it good then you will be up for the cost of a technician to come and check the house phone and connections
Apr 13, 2017 | Miscellaneous
Had a power outage, line down in the neighborhood. Tried to get back on computer, Google is blocking with an SSL error
Sounds like a connection error, maybe your internet is down still or you need to restart your modem and router. Here is some google help though just in case.
Check secure connection SSL error
Apr 20, 2014 | Microsoft Windows Vista Home Basic for PC
Need user manual for ideos -x5,u8800(HUAWEI) how to switch between normal phone line and internet line. i have one sim to use normal phoneline and internet
you will need an adsl in line filter splitter this will split your internet connection and your phone connection i from the phone line into 2 one goes to the modem the other goes to the phone
hope this helps
Apr 19, 2011 | Computers & Internet
Base appears to be shorted for phone connection. When I first hook phone line up I have a dial tone, but when I press stop on any handset or speaker phone the phone will not disconnect. The line eventually...
I have same problem but it will happen while I am in middle of talking. handset will go dead and say it is not connecting to base, but base indicates line is in use. I try it with other handsets to no avail
Apr 13, 2011 | Panasonic KX-TG9341T Cordless Phone
I have dial up internet connection. As soon as I placed the connection in the new computer p6340a the phone line was dead. this should not happen until a connection is made. Ted Andrews
If your modem is fried, this can result in a dead line... disconnect the line from the computer and test the line with a phone... if the tone is present, then connect the line back to the pc... If the line goes dead, you have a faulty modem or corrupt drivers
Apr 12, 2010 | Computers & Internet
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
Static on the phone
If it is a corded phone then probably wind gusts are compromising a connection from the pole to your house, if your lines are not buried. I if it is a cordless set wind could be the problems but most likely a HAM radio operator or CB radio is keying up in your neighborhood. They don't have a very tight bandwidth and the harmonic distortion is high. I would recommend getting one of the new 5.8 GHz digital cordless sets. They have excellent filtering capabilities.
Jul 08, 2009 | Uniden TRU8866 Cordless Phone
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Apr 02, 2009 | GE Security Simon 3 Wireless Home Security...
Internet connection dies when phone rings
There are a number of tests you can perform to find the problem unhook all the phones in your house and then call to see if it still does it. If it doesnt it may be one of your phones. If it does check the wiring in the jacks and make sure the wires are not backwards in any of them. If they all appear to be fine there maybe a problem at the pole or box whichever the company has installed in your neighborhood. Once you have determined that none of the above is present its not your fault and the providing internet company should not charge you to come out and check the outside lines. It can be as simple as a little short in the wire especially if its underground.
You may also wanna locate the phone box on the outside of your home and see if it disconnects when connected to there.
The box Outside Should Look Like This
And You'll Need To Disconnect All Of The Lines From These Plugs And Then Plug Your Internet Directly Into One Of Them. This Will Disconnect All The Phone Lines In The House. Now Place A Call To Your Home Via Cell Phone Or Have A Friend Call And If It Doesn't Disconnect Your Internet The Problem Is In The House.
If It Still Does Its The Phone Company's Problem And You'll Need To Call Them To Fix The Problem.
If This Does Not %100 Solve Your Problem Let me Know And I Will Continue Further Trouble Shooting With You.
Sincerely,
Michael Scott
Feb 04, 2009 | NetGear WGR614 Wireless Router
Router linksy swrt 54g
I have not been able to connect to the internet on my laptop in several weeks. I called my cable company which we have our broadband connection with and they told me to contact the internet service , he said everything was ok and referred me to you. I do not know whatcould be wrong with my laptop. It was bought for me Christmas last year. Thanks Mary K.
Oct 01, 2008 | Linksys Wireless-G WRT54G Router
Cnet CWR-854 Router Logo
122 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
valuesrespec
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
