Question about Sony Cyber-Shot DSC-M1 Digital Camera
My flash bulb is broken? where will i go to have it changed/repaired?
  • Sony Master
  • 586 Answers
The part No with description is give below:
1-479-040-11 FLASH UNIT (FL80000)
To get this part please see the link below:
http://www.partstore.com/Part/Sony/Sony/147904011/New.aspx?SearchTerm=True
Thanks for using fixya.
Posted on Nov 17, 2009
Testimonial: "thanks much this is very helpful."
I have a Chevrolet cobalt and the left turn signal will not work the inside light on dash flashes fast. I have changed the light bulb still doesn't work.
Fast flashing usually indicates that one of the exterior bulbs isn't functioning. You've checked front and rear signal lights, right? If the bulb is good, it could be corrosion in the socket, bad ground, broken wire, etc.
Oct 16, 2015 | 2006 Chevrolet Cobalt
My flash is not working.
Have you dropped the camera before?
If so, the bulb of the flash mechanism in your digital camera may have been knocked loose or broken.
Try cycling through the flash modes, forced on/off, automatic, red-eye, etc. Replace/charge the batteries; flash sometimes doesn't tend to work when it doesn't have enough energy to charge.
Try going to a dark area and seeing if the flash is at least emitting some type of light, if not, bulb itself could be the problem. After trying all of these steps, and you can't see that the flash is emitting ANY type of light what so ever, you can safely assume that the bulb inside the flash is defective or broken.
If that's the case, the only way you can fix that is by calling up Kodak and their support center and seeing if they can repair it for you.
Mar 06, 2011 | Kodak EasyShare C140 Digital Camera
Front passenger head lights keep flashing in and out
If you haven't already done so change the bulb and see if this corrects it. I broken element in the bulb will do this when the element bounces up and down and makes brief contact. If you have tried this then it could be caused from a broken wire on the headlamp harness or a bad headlamp socket. I would first remove the headlamp leaving it attached in the socket, with the lights on shake the harness and see if you can get the bulb to flash. If it does flash inspect the wires going to the headlamp socket for and damage or breaks and inspect the socket itself for a loose fitting bulb. If you find bad wiring repair it using water tight **** connectors that will need to be heated to seal the wires. If you find a bad or worn socket from excessive heat then contact you dealer or local junk yard for a replacement and again use water tight **** connectors or shrink tube.
Jul 30, 2010 | 2002 Chevrolet Tahoe
Gateway laptop power up problem
Try to identify first the bulb headlights that flash orange could be a bulb that indicate the charging status of the battery and if you do not find any guidance to know it you can remove the charger from the laptop or the battery if stopped bulb flashing the bulb is the function on shipping either key Fallow broken must be changed if the broken part was the outside plastic or even key Tish
Apr 20, 2010 | Gateway MT3705 Notebook
I dropped my flash, bulb broken
if it is charging OK,discharging is failed,discharging components must be replced,xenon tubr etc,contat camera tec.
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
No Picture
Need to change ur picture bulbs or tries to refits the bulbs.
Sep 24, 2009 | Panasonic PT-44LCX65 Television
Blinker wont work
Replace your "flasher relay, also know as a "blinker relay".Your local auto part store should carry them.
Sep 18, 2009 | 2001 Buick Regal
FLASH LIGHT BULB of my DSC H1 digital camera HAS BLOWN
You need to replace flash bulb board of DSC-H1 as shown in below image. (item # 304) Part number is as follows..
A1119331A ST-124 BOARD, COMPLETE
It is available in Part Store.
Replacement of ST-14 board (flash bulb board) requires expertise and solder work.
Thanks.
Jul 28, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash not working
this appears to be something that kodak would need to repair. Go to this link My digital camera is broken. How can I get it repaired or serviced? and follow the instructions on the screen, if this does not help then there is an option to send a repair request to kodak, which they will do free if it is still under guarantee.
I hope this helps
Jan 10, 2009 | Kodak EasyShare C330 Digital Camera
Broken flash bulb
Yeah, but look out, that capacitor can almost kill you! If you can find the flash bulb, it is very important that you do not touch the bulb with your fingers. Use rubber gloves. You may have to solder the bulb leads in.
Feb 23, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cyber-Shot DSC-M1 Digital Camera Logo
311 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
