Question about Plumbing
I replaced the cartridge on my Moen single handle kitchen faucet (the old cartridge had become quite stiff). Everything went back together fine. Now however there is alot of slack in the handle when the faucet is on. There's no slack when the faucet is off. I can't figure this out!
  • 119 Answers
You need to get the handle back on properly there is a groove on the handle that connects to the top lock nut older models had a chrome nut newer ones had a black plastic one
Posted on Nov 23, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen kitchen faucet
    Hi Steve-If the faucet is definitely getting water (making sure all the cut-off valves are open along the way), the Moen single handle faucets all use a replaceable cartridge that is available at home supply stores. This cartridge is what regulates the pressure and the temperature of the water coming out of your faucet. This is likely faulty. You'll need to close the supply valves (hot and cold) underneath your sink prior to replacing.
    Apr 01, 2014 | Plumbing
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Handle won't stay up
    I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
    Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    Cold water flow is slow and handle is starting to get a little stiff to raise and lower - what is wrong and how can it be fixed? Moen M7800 Kitchen faucet
    Not sure whether you are aware or not but most times, if you call moen with your model number and explain the problem your having, they will usually send you (free of charge-lifetime warranty) the part with instructions on repairing it along with it. You may have the 7800 series, but there are 3 or 4 different models if you check their site, and can identify the actual model, they will send you repair parts. Tell them you bought it ? years ago, and don't have the receipt, if they even ask.
    try this link, if no luck, get back to me.
    http://www.moen.com/replacement-parts
    Apr 16, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Handle is stiff and leaking at base. It appears I need a cartridge replacement. How do I access the cartridge? Thanks.....Keith
    Moen products almost all have a lifetime warranty.  I know they have a website because I queried & found a phone number called them & got replacement guts for my unit for about $8.00, Quality counts in my book!
    Jul 22, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    292 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
