Question about Xerox Phaser 8550DP Printer
Printer screen The Phaser is printing with lines through the print , how do I make these lines go away? Also the actual screen on the printer stays completely blank all the time, how do i fix this??
Your display is blank because the LCD unit is bad and needs to be replaced.
Posted on Jan 10, 2008
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 7400, lines on solid colours
Are the streaks evident when printing actual images? I was told by an experienced Xerox service tech that those solid-fill test pages can be misleading -- mine does the same but prints photos beautifully. I suggest printing some full page photos, check for the streaks. You've already done just about all you can.
Jun 19, 2014 | Xerox Phaser 7400DN Laser Printer
Half page comes blank then its starts printing...xerox phaser 3117
If the first line of the half printed matter is in the same possition as on original problem with toner cartridge. or the first line is actually the first
line in original may be the problem with formater board. Anyway check for paper settings.
Dec 19, 2013 | Office Equipment & Supplies
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Duplex printing problem
goto printer property and select 2 side printing .
Feb 26, 2010 | Xerox Phaser 4500DT Laser Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8550, scratch lines through printout
For the lines try the remove stripes and also the remove smears procedure you can run from the panel.
The Led screen is a known problem. Send Xerox an E-mail and they will replace it.
You have to pay for phone support if your not under waranty.
But they will replace the screen.
Oct 10, 2007 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8550DP Printer Logo
196 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
