Question about Aerogrow AeroGarden - Pro 100 Stainless Unit - w/Gourmet Herb Kit
Low water light always on even with topped off water level and hitting the reset button. What gives? Thanks!
  • 4 Answers
The float my be stuck, you can remove the chamber and free the float. Pull the chamber straight up and it should seperate from the bowl, the float can be loosened and made to move up and down with the water. If this does not work, contact AeroGrow for a float replacement.
Posted on Dec 17, 2009
  • 437 Answers
Go to www.aerogrow.com. I looked there and the question I looked at said your float may have sunk. They have a number to call to get a replacement for your unit.
HTH
Good Day.
Posted on Nov 18, 2009
Was awakened in the middle of the night by the F&P dish drawers (top drawer) playing the "Star-Spangled Banner" alternately with "Brahms Lulliby", lights flashing, lots of beeping! .....the lights...
Not funny Cindy - Any chance you can access the power breaker in the panel for the dishwasher? Sometimes with even short power bumps or outages, electronic controls get out of whack - Leave the breaker off for a minute and then turn it back on - As for the water level, I would question if the hookup was done entirely correctly - The idea is for the drain to connect to the most clear point of the sink drain - if you drain came with a pre-made Dishwasher drain connection, did the installer make sure that the plug was fully removed before connecting - Even in my mobile dishwasher I might get an inch of water, but not what you are experiencing - Good Luck
Feb 09, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
2000 vw beetle 2.0 L, low level coolant light...engine mil code 1256
not the pump but air in the system or a broken wire to the coolant level sensor
that sensor at the top of the radiator tank has to be completely immersed in coolant or the circuit is broken and the light comes on
same effect id the wire to that sensor is broken in the insulation
Jun 16, 2017 | Cars & Trucks
My dash brake light comes on sometimes when I brake, or hit a dip in the road or even start off to drive.
Check the brake fluid level. If its low, its time to have the brakes checked for wear. Whenever a "light comes on" check the fluid level associated with the light, thats always the FIRST thing to do.
Aug 03, 2011 | 1998 Ford Explorer
When I wash clothes the water level is always too low. It's almost like I have to do half loads or sit there holding the reset until it fills up all the way. Is there anyway to adjust that? It's a...
there is a unit in the top called a water level indecator it can be adjusted but if its working this bad i would replace it there not expensive
May 05, 2011 | Washing Machines
How do you get to level 2-a in the new super mario brothers
When you are almost to the end of level 3 of world 2. right before you hit the orange button that makes the water level rise. that's where you have to start. get to the left of the orange button, you may hit on accident, but just wait for the water to come down. once you are on the right hit it and run. make sure the water doesn't caught up to you. because if it slows you down, you won't have enough time. jump up and then swing as fast as possible to the opening above. Forget about the coins, I know they are tempting but you could always come back, and run to the left of the big area. there should be another orange button (note that the button will be there if the water level is still up!) if you time this right. the water level will rise again. Stay with the water level, it only goes up for a little while. so swim fast to the RIGHT! get on top of the open way. walk to the right. and you'll enter through an invincible pipe, only to come out into the the alternate ending for level 3 and into level 2A. Good luck
Mar 22, 2009 | Nintendo New Super Mario Bros. for DS
Light popped up last night on dash that looks like a water pipe
First place you need to go is to open the hood and check the actual fluid levels. Sensors sometimes give false info sometimes but actually looking at your engine has been and always will be the best way to know what's going on under there!!!
If you find coolant or something else is low, top it off and look around for any obvious leaks...Then watch that level does not drop again.
Post back if you need help with any repair info as needed.
good luck
Mar 16, 2009 | 2004 Jeep Grand Cherokee
1989 Saab 900 low level fuel light
You don;t say whether the fuel gauge is reading accurately, or whether it's always on empty. If the gauge is always showing empty, it's most likely a problem with the sending unit in the fuel tank. Check the resistance across the two terminals of the sending unit.
On a C900, the fuel sender level unit is separate from the fuel pump and located on the right side top of the tank, accessible by removing the trunk floor lift up panel (the pump is located on the left side top of the tank.
Possible problems are: electrical line off or broken, float not working (it's fairly delicate); or gauge not working.
Test the resistance of the sending unit with the lines disconnected, the resistance should be 2.6 to 3.8 ohms full tank, 63.3 to 67.5 ohms empty tank; and test for voltage across the top of the sender unit, if no voltage, that's likely the problem!
If the gauge is otherwise reading accurately (showing 'full' for a full tank, etc) then the problem is likely a gauge malfunction and can be simply replaced.
Saabreur
Jul 10, 2008 | 1989 Saab 900 4 Door
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Jun 05, 2007 | Miele 24 in. G638 Plus Free-standing...
Aerogrow AeroGarden - Pro 100 Stainless Unit - w/Gourmet Herb Kit Logo
183 people viewed this question
Top Aerogrow Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
