Question about GE GTS22KBP Top Freezer Refrigerator
Is there a reset button on GE GTS22WC? When we plug it back in the motor does not come on?
  • 441 Answers
No reset buttom but after the unit sits with out power for several hours it will reset
Posted on Nov 17, 2009
Replaced broken motor coupler and motor still saying problem has been detected with drive system
With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed.
Dec 01, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
MODEL #WHDRR418G1WW GE WASHER,THE LIGHT (RED0 ON
unplug unit for 1 minute plug back in and open and close lid 6 times within 12 seconds this will reset the motor.
Feb 26, 2010 | GE Washing Machines
GE MODEL GSD900D ISN'T PUMPING OUT THE WATER. IS THERE A RESET BUTTON?
There is no reset button. The most common problems are drain hose blocked (new or plugged disposal?), or the pump/motor assembly has been leaking. Is the motor turning? GE motors will turn from the time you turn it on until dry cycle. Remove the lower panels and observe the drain solonoid on the left of the motor. The silver plunger should go down when in drain cycle. Look for any corrosion meaning you have had a leak. If so, it is probably time for a new dishwasher. The newer dishwashers are much quieter, clean better, and use less energy. The best price on a new pump assembly is around $120 plus shipping.
Hope this helps,
Ken
Oct 16, 2009 | GE Dishwashers
My washer does not agitate. i've cycled in many times, unplugged it for awhile. nothing works
Reset the motor, unplug for 2 minutes then plug back in and open and close the lid 7 times slowely to reset computer that runs motor.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE washer won't agitate or spin
un plug the machine , wait 30 sec. plug back in , open and close the lid completly 5 times with in 30 sec. if the problem is just needing to be reset this will do it if not you need to replace the motor
Jan 18, 2009 | GE WBSR3140DW Top Load Washer
GE topload washing maching won't spin or agitate. Where is the reset button
Here's what the GE technician just did at our house to reset the electronics:
Unplug the machine for at least 30 seconds.
Plug it back in, then open and close the lid six times.
That fixed my problem. Good luck with yours.
Dec 06, 2008 | GE WBSR3140DW Top Load Washer
Bad odor in freezer
the only source for odor in a refrig is from food. check to be sure that nothing has gone bad in the refrig section as well as air circulates back from the fresh food section as well as the freezer. if you stil cant find odor source try charcoal or unscented kitty litter in a small container to help remove bad odors..
Dec 12, 2007 | GE GSS25JEMWW Side by Side
Actual model is WWA3650SALWH
JUST A QUICK SUGGESTION FOR YOU ... ON MOST WASHER MOTORS THERE IS A SMALL RESET BUTTON ON THE MOTOR ITSELF. TRY RESETING IT ... IF IT RESETS AND POPS RIGHT BACK OUT OR IS JUST FLOATING THE MOTOR IS MORE THAN LIKELY BAD OR ... YOU MAY ALSO HAVE A CAPACITOR START MOTOR. THE CAPACITOR IS UNDER A COVER ON THE MOTOR ITSELF THAT CAN BURN-OUT OR GO "OPEN CIRCUIT". THEY ARE REPLACEABLE. IT SEEMS YOU HAVE CHECKED ALL THE OTHER CULPRITS I USUALLY SUGGEST. I HOPE I COULD HELP OUT.
May 02, 2007 | GE WWSE5240D Top Load Washer
GE GTS22KBP Top Freezer Refrigerator Logo
496 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
