Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
Bluetooth headphone works with windows 7
Auriculares Bluetooth funciona con Windows 7
3 Suggested Answers
  • 3 Answers
SOURCE: installing the bluetooth software
http://drivers.anycom.com/bluetooth/usb-200-250/anycom-bluetooth-usb200-250-windows-v5-1-0-4200.exe
This should work for you.  Best of luck.
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Posted on Feb 24, 2009
Polaroid pbh4000 head phones , i cant get connection through my Bluetooth dongle , using windows xp .
I think there issnt any support for these headphone on a win7 or lower OS. I mailed Polaroid asking for help, but there aren't support for older windows.. mine is working fine on my windows10 laptop, but on my windows 7 workstation, I cant get it working either..
It shows up as a "Bluetooth Peripheral Device" but there aren't drivers available for it.
Oct 10, 2015 | Polaroid Audio Players & Recorders
Connect windows 8 laptop bluetooth dre beats
I had the same problem earlier and tried to solve it... First make sure you re-install any bluetooth drivers that you had to delete if you upgraded from windows 7... I had to delete mine in order to do the upgrade. If your laptop comes stock with windows 8, search your computer's website for any bluetooth drivers that you should have. Once you have these installed, proceed. *This might work even without the above procedure so try it out* Right click your bluetooth icon and go to add bluetooth device. Then press and hold the on/off button on your beats wireless till the LED starts flashing blue... It should show up on your laptop. When it does, click on it and it should start the pairing process. Once it's done pairing, simply go to your volume icon at the bottom right of your screen next to your clock, right click on it and go to playback devices... In there, you should see your beats wireless headphones as one of the options. Select them and click 'Set Default'. Then go to youtube or your itunes and play away :)
Dec 26, 2012 | Beats By Dr Dre Beats Solo Hd Bluetooth...
Mi manos libre 220 no funciona no enlaza con bluetooth de ningun tipo , no se enlaza con ningun telefono , enciende bien y apaga bien
Si su 220 enciende bien y apaga bien parece que no hay un problema con el aparato. Para enlazarlo con otro aparato bluetooth es importante seguir estas instrucciones. Va a necesitar traducir las instrucciones porque estan en ingles. Aqui esta la pagina del sitio de web.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Bien suerte de Headsets Direct - 800-914-7996.
Aug 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Como conectar bluetooth madcatz playstion 3
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
Dec 28, 2010 | Mad Catz Bluetooth Headset for PS3
Need driver for targus mouse amb04us win7
Targus Bluetooth Mouse Driver: Direct Download from Targus.com
Don't be mislead by the title of the file, the file covers any Targus Bluetooth Mini-Mouse.
Dec 07, 2010 | Targus AMB04US Mouse
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Oct 30, 2009 | Audio Players & Recorders
Driver de audio no me funciona el auricular con windows xp
Lo sinto, pero los drivers de audio para Windows XP no existen en el sitio web de Toshiba.
Puedes intentar el driver para Vista que puedes descargar aqui
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
412 people viewed this question
Top Insignia Radio Communications Experts
woodzowl307
wwlvictoria
wwlvictoria
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
