Medion laptopMD96015 has power will not boot. HD used external is accessable.No boot no display when internaldonrichardson.??
3 Suggested Answers
  • 733 Answers
SOURCE: External disk unaccessible
when you pull out the external disk it must be stoped ,i think you did not do that,so check al the driver's for usb all 6 of them reinstal and it should work but remember to stoppet next time.
Posted on Nov 30, 2009
SOURCE: Cannot reinstall Win7 on a Medion tower
Have you tried replacing your drive? You could instal a smaller drive for your windows and then use the 1,5TB for storage? A lot of videos on youtube that can help with installing a new drive into your tower.
Posted on Dec 14, 2012
Dec 14, 2012 | Computers & Internet
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
After power was of for some time, I cant start the computer it only say power on in the display and fans are running but not hard disk My pc is a Medion MD 8800 I have been told it is something about...
Make sure the video cable is not loose at the display and the PC. Try connecting a known working display. Try booting in Safe Mode, if that works, shut down and boot normally. It is possible that the memory modules are loose. It is also possible that the on board video card is defective. Good luck. I hope this helps. Have a good day.
Apr 25, 2011 | Computers & Internet
I have a systemax desktop that runs XP. I installed a Seagate 2T external hard drive to store pics, files, etc. When I turn on the systemax, it attempts to boot from the external hard drive and will not...
Pressing f10 during system restart will gain you access to the bios. Using the arrow keys scroll to the boot sequence and hit enter. this should allow you to choose from , and select a primary boot order sequence. Follow the on screen instructions to make the changes. Then hit esc button. be sure to save and exit setup.
Jan 23, 2011 | Systemax (036052) PC Desktop
Hdmi out to tv does not work medion md 8830
access your video control panel located in the control panel . You must manually switch your video output sometimes , from your default display to a external display.
Nov 18, 2010 | Computers & Internet
My Maxtor Onetouch 4 500gb external hard drive is not working, the light does not come on any more as if there is no power. When I tried a universal power cord the light blinks really fast, but my computer...
First thing you need to do is to confirm your Power supply is working, i think its a 12 volt adaptor so check wattage rating and then try to power a router or a device that uses the same voltage and wattage with it, an easier way is to check whether the light blinks once very fast right when you stick the adaptor into the external HD's back, if it does, download hyrens Boot CD from thepiratebay.org and burn it to CD...Most of the tools on Hyrens boot CD work in DOS but a limited amount works in windows, try booting into windows and try using the partition recovery tools like undelete etc, if this does not work you will have to take the actual HD out from the case by dissassembling it and then plug the actual HD without the case straight into your pc via sata cable, restart your pc and instead of booting windows boot the hyrens boot CD Menu, now use the partition and HD checking tools, this should work, if it does not, your HD is irreparably damaged and you might need to mail it to data recovery experts to get your original data back, Hope this helps..
Oct 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
No screen activity
If you used an external monitor and got nothing on it, then the problem is the video card.
Apr 24, 2010 | Toshiba Satellite A205-S5879 Laptop
Nov 30, 2009 | Medion (40010998)
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
David Payne
David Payne
