Question about Maytag PTB2153G Top Freezer Refrigerator
We are hearing a sound like a clock buzz every 10 minutes. why
  • 106 Answers
If your frig has a factory installed Icemaker and you never hooked it up to your water in your house, the Ice maker is looking for water. Shut off the ice maker by lifting up the metal arm on the ice maker. or unplug it.
Posted on Nov 17, 2009
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Mar 04, 2016 | Televison & Video
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Buzzing sound under dash of 95 jeep grand cherokee
There can't be any noise after 5 minutes. There are capacitors that take a few minutes to drain down. It could be your clock winding or your abs cycling. Listen and see if it's coming from your fuse box a relay
Jan 05, 2012 | 1996 Jeep Grand Cherokee
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Dishwasher starts to buzz when running. This occurs around the 65 minute and the 49 minute and 47 minute mark. this lasts for a few minutes or so. It sounds like a motor is jammed. The sound then goes...
Have you noticed a malfunction as a result of the buzzing? If not, let it do its thing until something fails! You could be hearing a solenoid. Otherwise, contact an appliance service company.
Apr 14, 2010 | KitchenAid KUDS01IJ - Multiple Color...
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
Maytag PTB2153G Top Freezer Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
