Computers & Internet Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 sebring . won.t shift into 2nd gear - Extron Electronics Switching and Transmission System (tps150-1)
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Nov 23, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
25311
Points
209
Diacgnostic scanner,if there is speed sensors codes,is just replace it,its common in crhysler trans.
Why want my 05 shift from 2nd gear. Started all at once and the other gears are just as good as new, not leaking
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
hi i have a 2004/05 misubishi lancer just recently the neutral light keeps blinking ... (2nd to 1 st gear ).i replaced atf and filter it does the same thing since ? bought ?t 3 ... having is driving with the overdrive on it won't shift when shift into 3rd gear it just ... I have a ls400 and my auto transmission shift hard when I ...
trouble shifting from 1st to 2nd gear [Archive] - The Sportster ...
xlforum.net/vbportal/forums/archive/index.php/t-12257.html
Aug 25, 2005 - 28 posts - ‎18 authors
My co-workers tell me I am just not shifting into 2nd gear properly, but I am making an effort to make ... When it won't engage in 2nd can you kick it up to 3rd OK & do the other gears engage OK? ... 25th August 2005, 13:05.
Transmission won't shift out of 2nd gear - Honda TRX Forums: Honda ...www.trx450r.org > ... > 450R Performance and Mods. > EngineDec 24, 2012 - Just rebuilt my 05, new crank and piston (it did not blow up). I didn't touch the gears or shift forks except to make sure they spun and were not.Won't shift out of 2nd. [Archive] - Chevy TrailBlazer, TrailBla
1helpful
95 Chrysler Sebring transmission shifts to 2nd gear only
I don't want to jump ahead with bad news, before
you have a trans shop road test & weigh in
But having owned a trans shop & worked on those year
chryslers in the 1990's
I think your going to be rebuilding it
1helpful
I have an 04 yz 125 that won't shift into 2nd but
2nd gear is at the bottom of the shafts if the tranny is stacked in the mag side case. So it is controlled by the bottom fork. You should be able to shift it thru all the gears by turning the shift drum. Make sure as you shift the shafts stay all the way in the output shaft and idler shaft bearings. As you shift it, look for full mesh between the wheels(shaft that goes to the clutch) and the gears across on the output shaft.
If that all looks good, the shifter cluster(on the end of the shift drum, with the 2 dogs that engage the notched wheel on the end of the drum) may not be lined up properly. If the gears and shift drum are new, I'm thinking I'd look there first. Good luck!
2004 chrysler sebring AT Trans prob
have electronic transmission module checked
Tranmission shift problem
Check the gearbox filter, it may require replacing.
Its inside the gearbox below , remove the (gearbox)sump and you will notice it.
Top Extron Electronics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
