Question about GE JVM1870 Microwave Oven
Why is my microwave oven sparking?
Why is my microwave oven?
  • mmatteson2 Nov 17, 2009
    the paint isnt chipped but i recently replaced the light bulb and when i put the light cover back on the metal was rubbing against the top because it started sparking and now the metal piece of the cover is black. Now there is no cover on the light and it is still sparking...what do i do?
  • 441 Answers
If the paint on the inside of the micro is chipped off in some places, it will ark to the exsposed metel
Posted on Nov 17, 2009
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
Sparks when on microwave cooking
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
kk
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Sparks!
your oven have been damaged don't on it again and again.....
it need reparing of heeted wires inside the oven
plz. do not use it, its may be harmfull to you because sparks shutdown your all home light or chances of electric shock
Oct 17, 2008 | Daewoo KOC-925T Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
GE JVM1870 Microwave Oven Logo
124 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
