Question about Nokia N95 Cellular Phone
My nokia n95 will connect to my avantalk btck-12b bluetooth device, but can't get no sound comes through speaker of bluetooth. have tested bluetooth with another phone and works correctly.
How can i connect bluetooth ce0681 to nokia n95
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.
2. Put it into "shown to all" mode.3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.5. It will ask you for a passcode, just enter 0000.6. Pair both devices now.7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jan 21, 2011 | Nokia N95 Cellular Phone
My avantalk btck 10b wont connect to my blackberry curve
Had the same problem. It all looked OK and it found the Avantalk, but it would not 'pair' and kept failing. I decided the problem was probably with the Avantalk unit and wondered if I had paired it with too many other phones so decided to do a 'reset' on it. This is achieved with the Avantalk turned 'on-standby', with the two blue flashes every few seconds. Press and hold the up and down volume buttons for more than 5 seconds, at which point the red and blue lights will flash on and off 5 times very quickly. The unit should then return to its 'on-standby' state again. Switch it off (larger MFB phone button), then on again and then set it into pairing mode (immediately after the Avantalk has come on, press and hold the MFB button again until the red and blue lights are flashing), then go through the searching blue-tooth device and so on again with you phone. It should all work now.
Cheers... Rob.
Oct 15, 2010 | Cell Phones
My new avantalk btck-12c mic.does not pickup my voice is there an adjustment ?
I have a avantalk btck12c car kit buy it calls the wrong number . Do I have to put my contacts into my speakerphone My phone is a iphone3g
May 15, 2010 | Pantech Avantalk Wireless Bluetooth Visor...
Why does my avantalk BTCK 20 flash blue? if it flashes red that means it needs to be charged but why does it continually flash blue around every 3 seconds once I have it on? Looking forward to hearing a...
The bluetooth suppose to be a signal, and the posibility like the phone to activate it will often precising by the way that the bluetooth is running or working. For me, it is logic!
Mar 25, 2010 | Samsung Avantalk Wireless Bluetooth Visor...
Nokia N95 Bluetooth
I have just spoken with 3 as I had the same problem with my Nokia N95.
The solution is:
Menu
select Tools
select Bluetooth
at top option blue tooth on - select right hand navigation button
it will say (no paired devices) select Options and select new paired device this will then seach for other blue tooth devices.
Good luck everyone
Jun 09, 2008 | Nokia N95 Cellular Phone
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
Bluetooth connection not working Kenwood KCA BT100 with KDC W7537U and a Nokia N95
Well... I'm sure mine worked ONCE! I have the BT100 and KDC-W7534U. It worked fine with my Nokia N80 but with my Nokia N95 It connects fine but i cant hear or be heard when the call is answered.Interestingly I cannot use the headunit to dial a number anymore. If i was to be on a call BEFORE connecting the headunit then it works. But once the call ends and i select an input source - the phone has the same symtoms as above again. I have checked all the profile settings and set the enhancment to be active on the active profile. I thought Bluetooth was a standard and it was just meant to work if it was bluetooth compliant! ...Grrrrrr!
Jul 26, 2007 | Kenwood KCA-BT100 Wireless Headset
Nokia N95 Cellular Phone Logo
170 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
