Question about ViewSonic N3251w 32 in. LCD HDTV
I was away for 2 days , came home and there is NO power to my Viewsonic
  • mjacobbi Nov 17, 2009
    OK Thanks .. I think it is the power supply ...
    do I have to take off the whole back panel to get to
    it?
  • 11,361 Answers
Check outlet, then look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
  • Bud Martin
    Bud Martin Nov 17, 2009
    Yes, you have to remove the stand and the back panel, you will need long philip screw driver to get the stand off.
I was using my computer one day. I shut down for the day,everything was fine. The next day I attempted to turn it on and the green light did not come on and I had no screen. Everything was dead.
More likely the power supply had died, look for bad caps with leaking/bulging top, fuse, etc.
See failed VIEWSONIC in my albums.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 11, 2010 | ViewSonic VA1912w 19" LCD Monitor
My viewsonic vx2255 wont turn on sometimes i have also found a noise coming from the powerboard and once it goes away the monitor will turn on
You may have caps leaking in the power supply or arcing from the lamp assemblies, you need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 16, 2010 | ViewSonic VX2255 Monitor
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Exactly the same problems.. It's been repaired 2 times and last night it went totally black... Bummer... but the image quality is excellent ( when it works) boooo viewsonic.. Natalie
What parts were replaced, or cheap parts were used? More likely to be either bad caps in the power supply, or bad backlight inverter circuits, see failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
My TV viewSonic after 2-3years would not to turnon
Have the power supply module checked out, it can be as simple as a blown fuse or bad filter capacitors.
Oct 30, 2009 | ViewSonic N3251w 32 in. LCD HDTV
'memory recall ok' displayed always on the screen. Does not go even if selected yes or no. Why?
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Nov 04, 2007 | ViewSonic G90fb 19" CRT Monitor
ViewSonic N3251w 32 in. LCD HDTV Logo
133 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
