Question about Maytag PYE2300AY Electric Dryer
Went from a three wire to a four wire dryer connection... what post does the red wire go on to? White, Black, or Green?
  • Maytag Master
  • 1,606 Answers
On the dryer , you have 3 terminals on the block . The red goes on one side , either side , the white goes in the center , and the black goes on the other side . Makes no difference on which SIDE the red and black go on . The white MUST go on the center terminal , and the green MUST be grounded by any screw screwed into the cabinet .
Posted on Nov 17, 2009
Had to put dfferent plug what is the order the wires go on dryerto plug
White goes to middle post. Red goes to post with red wire and black to black. Green goes to green ground screw around opening for terminal block.
Nov 12, 2017 | Dryers
It looks to be a three prong selection an I have four so what to do
Connect red to red side, black to black side. White in the middle and green to the frame of the dryer. make sure all connections are tight but beware of overtightening the electrical terminals
I recently fixed a dryer exactly like this that had a 4 prong setup. Take a look:
Nov 27, 2012 | Dryers
Can u help me please we're do the brown grey and white with pink line wires go
Four-Wire: Green
The green wire is the ground wire, and it is the difference between a three-wire and a four-wire cord. (In the three-wire system, the ground wire and the neutral wire are the same.) The green wire connects to the dryer frame. Look at the cord-connection terminals on the back of the dryer. Very close by, you should see a screw sticking out of the metal panel. It will be labeled "external ground connector" or something similar. Connect the green wire to that screw.
Four-Wire: Black
Most appliances in your house run on 120 volts of electricity, some on 240 volts. The dryer needs both--240 volts to run the drum and heating element, and 120 volts to run the timer, thermostat and other components. For this reason, the dryer cord has two live or "hot" wires--one black, one red--rather than a single hot wire. The dryer draws 120 volts from each hot wire to get the 240 volts it needs for the heavy work, then pairs one hot wire with the neutral wire for the 120 volts to run the smaller functions. Look again at the connection terminals on the back of the dryer. There should be three screws in a horizontal row. Connect the black hot wire to the terminal on the left.
Four-Wire: Red
Connect the other hot wire, the red wire, to the terminal on the right. (In truth, you could connect either hot wire to either hot terminal, but it's standard procedure to put the black on the left and the red on the right, so do so.)
Four-Wire: White
The white is the neutral wire, and it connects to the center terminal. There may be a metal strap attached to this terminal. That's a ground strap. When a three-wire cord is attached, it serves the same function as the ground screw mentioned above.
Three-Wire: Gray
If you have a three-wire cord, then all three wires will be gray. They're arranged side-by-side with the hot wires on the outside and the neutral wire in the middle. Attach the hot wires to the left and right terminals and the neutral wire to the center terminal. Make sure the ground strap is attached to the center terminal.
Nov 20, 2012 | Dryers
I have a maytag neptune dryer #MDE5500AYW and I am trying to convert from a three prong to a four prong connection. the four prong has a red, white, black and green connection. the old three prong, had a...
yes,hook up the black with the black the white with the white and the red where the blue was,now the green is just a ground wire,all you have to do is connect it anywhere to the metal frame of the machine just to ground it,look around there should be a screw somewhere near the other wire connections if not remove any screw and connect it and it will be fine.
Sep 04, 2011 | Dryers
Just moved and outlet for dryer is different.
Connect the red, black, and white wires of the new cord to where the red, black, and white wires of the original dryer wires are connected to but disconnect the ground wire (green/yellow wire attached to the cabinet) from where the white wire is connected to and connect it instead to the fourth green/yellow wire of the new cord.
Apr 12, 2010 | Whirlpool LER5636P Electric Dryer
I need info for changing the power cord from a 3-wire cord to a 4-wire cord. I have a Maytag Dryer Model MDE9316AYW and I am not sure wher to connect the wires. It looks like they connect (from left to...
The correct way is actually as such...Green (ground) to the frame/chassis. Red, white, then black. See the image I attached for a reference.
Hope that help`s. Good luck.
macmarkus :)
Mar 06, 2010 | Dryers
We have moved and the three prong cord now needs to be four prong
Ok here is how to hook up looking at dryer. Left brass screw is hot put red or black wire on. Center screw silver is neutral put white wire on. Right brass is also hot put the red or black wire on which one you have left. The green you ground to the dryer body or you can put with the white wire.
The reason why you have to hot wires is that it is a 240 volt dryer. Each hot wire caries 120 volts. The hot wires are the red and black. The white is a neutral witch is also a ground
I hope this helps. If you have any questions please ask before you rate.
Good Luck And Thank You for the post
Oct 20, 2009 | Dryers
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
