Question about Canon MP830 All-In-One Printer
Can't send or receive fax hagans@loadednet.com.au
    Scholar:
  • 82 Answers
Check the cable, i.e. plug an analogue phone into the cable and listen for a dial tone. If none, are you plugged into a digital line?
If a dial tone is heard, is it an intermittant dial tone (message waiting) because this can stop the fax from working. If so, resolve this and try again.
Do you need to dial a number to get an outside line? If so this needs to be entered before the fax number on outgoing faxes.
Posted on Nov 17, 2009
How do you send a fax on a canon mx340
try to download manual from the following site
http://support-au.canon.com.au/contents/AU/EN/0300299101.html
If above link does not work , clickon the below link to proceed....
http://www.canon.com.au/en-au/For-You/Printers/PIXMA-InkJet-Printers/MX340
If you like solution, please rate & vote...
Thanks
San
Mar 14, 2011 | Canon MX340 AllInOne InkJet Printer
The fax receives but i cannot send fax?
I would suggest you to try Popfax.com internet fax service. I use it for several years, and never got problems. It is cheaper than other providers. Try it for free on FreePopfax.com.
Jul 24, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
My sharp AR-M207 all-in-one does not send or recieve fax
dear sir good day the link http://support.sharp.net.au/drivers/driversearch.asp contain the driver for machine but the problem may happen from the tel line or from other fax sender ... so please first reinstall the driver and try to send or receive fax from other one thank you and good luck
Dec 26, 2009 | Sharp AR-M207 All-In-One Laser Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
I need to print instructions on how to use a brother fax -645 machine. how to set and send faxes
An on line manual probably does not exist. Put paper in feeder face down, dial number, press send.
Sep 11, 2008 | Sharp UX 108 Roll paper Thermal Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Junk Faxes
Rita Lee, I can't find my manual for this model but what I would suggest is turning off the "auto receive'" function. This is what I found online.
Depending on what (FX,AU,TM.TL) is displayed on the right hand side. Use the Ans.Mode/Contrast button to change that to TL is displayed.
The fax will not accept incoming faxes but you might also have a problem with the actual line being busy.
If you don't have the book I can send you the link.
I hope I have been of help.
MM85
mediaman85@mchsi.com
Dec 28, 2007 | HP 1040 Plain Paper Inkjet Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
old marine
old marine
