Question about Amana PTC123B35AE Air Conditioner
Heat setting blows cold air - Amana PTC123B35AE Air Conditioner
  • 534 Answers
You have a bad heater coil. This coil is located behind the evaporator coil in the unit. To access this coil you will need to remove the a/c from the casing. Right behind the coil you will see a metal box that has metal strands crisscrossing inside of the bos this is your heater coils. Take the model number and serail number to an appliance parts house for replacement part. Good luck on your repairs hope this helped
Dave
Posted on Nov 17, 2009
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Blows heat on passenger side only . Blows cold air on drivers side only
A nice radiator and heater core flush should fix you up.
Nov 17, 2014 | Cars & Trucks
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Kia Sedona- center and third row heating vents blowing cold air
This model has a rear heat/cold blend door actuator. Its an electric motor that moves the duct door from hot to cold. When they wear out, they're usually stuck on the last setting
Nov 13, 2013 | Kia Cars & Trucks
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
When I turn on the heat in my 2004 mazda mpvicon1.png the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
Jan 14, 2011 | 2004 Mazda MPV
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
Amana PTC123B35AE Air Conditioner Logo
139 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
