Question about Casio Exilim EX-S500 Digital Camera
Casio exilim ex-s5 flash doesn't work, stuck on "flash off" setting
SOURCE: Casio Exilim EX-Z850 Red Light Flashing
I have been having this same problem. It doesn't happen everytime, but there have been a number of occasions when my Exilim Z850 would display a blinking red light and refuse to take pictures. I thought it was a battery issue, so I tried buying a new battery, eventhough I observed this problem soon after the camera was newly purchased. The new battery didn't help resolve the issue. So I do hope someone out there has figured out what's wrong and will let us know.
Posted on Dec 27, 2007
SOURCE: Casio Exilim EX-Z850 - Mode Dial Does Not Work
I'm having exactly the same problem,
Posted on Oct 16, 2008
  • 89 Answers
SOURCE: Casio Exilim EX-Z60 6MP lines
No, it is not caused by settings. Probably CCD sensor is bad. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Posted on Sep 18, 2009
dlundmark
  • 797 Answers
SOURCE: all my images turn out blurry when i take a
A number of things can be wrong on this one.
Is your lens clean? Has the camera ever had an impact that you know of, especially when the lens was extended.
Any of these problems can lead to what you have explained.
Can the zoom work at all to the limit and back again?
The lens may be off track a bit.
I will recommend the following, but this action may damage your camera even more, so do it at your own risk.
As the camera is turned on, gently pull on the lens as it extends. And as it is turning off, push on the lens as it is going in. This action may make the lens jump back on track. It may damage it more, so be careful.
If you still have the problem, try this: Turn the camera on, go to the menu and set all to default, or factory default. Then try the camera, and see what happens.
If it is still not right, then there may be an internal problem such as a component default or failure, or possible mechanical problem.
If all fails, then it either needs repair or you may opt to sell it on a site such as Ebay for repairs or a fix-it as is.
Hope it works.
Posted on Oct 25, 2009
  • 11967 Answers
SOURCE: will not power on and "lens error" message casio
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 09, 2009
How do I set up the auto timer on my Cascio EX-S5 EXILIM canera ?
In the record mode, press MENU, select the Rec tab, select "Self-timer", then select the desired mode. Start the self-timer by pressing the shutter release button.
Full details are in the "Using the Self-timer" section of the manual (page 62 in my copy). If you need the manual, you can download one from the manufacturer's web site at
http://support.casio.com/pdf/001/EXS5_MF_FB_090401_E.pdf
Aug 02, 2011 | Casio Exilim EX-S5 Digital Camera
Flash setting is stuck on "flash off" and wont change
The flash settings don't work in some modes...what mode do you have the camera set to?
Jun 26, 2010 | Casio Exilim EX-S5 Digital Camera
Casio EX-S5 camera, how do you set timer so I can be in pix
In the REC mode, press [MENU], select the REC tab, then select "Self-timer."
Dec 20, 2009 | Casio Exilim EX-S5 Digital Camera
Need usb cable to casio exilim camera EX-S10 what type of USB connector is on this camera, not mini A or B. thx
i f i remember correctly, this camera has input/output terminals. both for USB/AV port and a USB: high speed USB.
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ120460169326QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item1c0bfc506e&_trksid=p3286.c0.m14
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ110426500160QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item19b5eeac40&_trksid=p3286.c0.m14
Aug 31, 2009 | Casio Cameras
Exilim ex-s5 camera problem
Check on the computer that it has only one file on card.
Aug 12, 2009 | Casio Exilim EX-S5 Digital Camera
I have a casio exilim EX-Z60 the mians battery charger flashes constantly red when I place in my battery, but does not charge the battery, can you advise please
I have a casio exilim ex-z60 which I bought 2 yrs ago. I've had problems with my flash going off each time I turned on and off the camera, about 5 months ago. Now the flash does not work. Need help on how to restore the flash bulb or battery in the camera.
Jul 28, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
350 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
