Question about Compaq Presario Notebook
My computer screen has moved to the center on both sides what can I do please
  • 691 Answers
Hello
Thank you for using FixYa.
can you check the screen res, this maybe been changed by mistake
Thanks
Richard
Posted on Nov 17, 2009
Hcl moniter screen adjust problem
hi. this may be from EEPROM IC. you can program it or replace IC with new one and then program it.
Apr 27, 2015 | Computers & Internet
Screen off center
Hi!
Does the screen correct itself when you move the screen up and down?
Please advise.
Mar 08, 2015 | ASUS Computers & Internet
Plastic cover
How to remove back cover of ViewSonic G71F+. First remove the 3 screws at the bottom , one on each side and one above the VGA cable. Now look for three small slots on the top of the monitor near the screen. From the side opposite the screen insert 2 medium-small flat blade screwdrivers into the center slot and the slot on one side at an angle of about 25 degrees from the top plane of the monitor then gently pry up by pushing the screwdriver handles toward the top plane of the monitor. Once the plastic latch in the center and one side are released move the screwdriver on the side to the opposite side to release that side.
Mar 07, 2014 | ViewSonic Computers & Internet
I did touched my bios and nothing when i start my pc anymore! help! lepic48@hotmail.com Bye! I would want the original configuration please i'm really stuck and i'm a beginner! Thank you!
You have to reset the bios. unplug the computer and remove the side panel. isually the left side looking at the computer. You'll see the motherboard. Look fot the disc type flat bettery on the board. remove the battery (pay attention which way the nattery faces). Now look for the jumper cal, sometimes red or black. It will be labled bios or clr cmos on the board. It's near the bettery. the cap is on 2 pins with one pin open. remove the cap (jumper) and move it to the next pin thats open. if it's on the center pin and right pin move it to the center pin and left pin. after it's there a few seconds move it back. reinstall the battery and plug it in. turn on the computer and it will boot with a bioes screen. set time and date.
Mar 26, 2011 | Gateway GT5404 PC Desktop
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Start bar was on the bottom of screen now it is on the side How do I get it back on the bottom
try clicking in the center and dragging diagonally from side to bottom.
this is how most taskbars get moved.
Jul 27, 2009 | HP Computers & Internet
Vertical screen adjustment-compaq model 7550
u must click on any button on the screen and try to control one by one till u find the destination which u want
Jun 06, 2009 | HP Compaq FS 7550 17" CRT Monitor
Picture off center
If you were in the technician menu then look for the HCENTER adjustment (horizontal centering) then move accordingly.
Jan 31, 2007 | Hitachi 43FDX01B TV
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
